By martin_g
#60192 Thank you for the speed tests!
Concerning your problem: what is your HW? What does the config look like after reset?
If it is the default again, flashing failed. You might try it again with a better power supply, (best with a bigger capacity parallel to Vcc and GND).
By Ribeiro Santos
#60245 Hi,
Has in my previous post, with "show" command it shows:
Code: Select allAP: SSID von PW:von23 [Open:0] IP:192.168.4.1/24
even, after reboot (power off and on). So, I assume it saved the new config, but continues as "MyAP" and open.
I will try to compile with hardcoded these settings.
Happy new year.
