By macross
#62948 Hi all
need help here
I was develope some WSN robot
right now I was using 2 ESP8266, one act as a WSN sensor node and other act as a robot node
that robot was working when got data from other WSN sensor node (right now light up LED would be okay)
I would like to send temperature data sent by WSN sensor node, and light up LED in WSN Robot
when the temperature reach 33 Celcius
the code is based on mesh example, and I was able to send data and get data
the funny problem was
i cant use that data to drive my robot
when I write it on serial the data was "0"
I dont know what to do
need help with this...
for WSN sensor node code (using DHT11 temperature data)
#include <ESP8266WiFiMesh.h>
#include "DHT.h"
#define DHTPin D4
#define DHTTYPE DHT11   // DHT 11
int temp, humid;
unsigned int request_i = 0;
unsigned int response_i = 0;
String manageRequest(String request);
DHT dht(DHTPin, DHTTYPE);
/* Create the mesh node object */
ESP8266WiFiMesh mesh_node = ESP8266WiFiMesh(ESP.getChipId(), manageRequest);
 * Callback for when other nodes send you data
 * @request The string received from another node in the mesh
 * @returns The string to send back to the other node
  // Read humidity
  humid = dht.readHumidity();
  Serial.print(humid);
  Serial.print(" Rho,  ");
  // Read Temperature
  temp = dht.readTemperature();
  Serial.print(temp);
  Serial.println(" Celcius");
  /* Print out received message */
  Serial.print("received: ");
  Serial.println(request);
  /* return a string to send back */
  char response[60];
  sprintf(response, "Temperature send %d for WSN Robot Node ID %d.", response_i++, ESP.getChipId() );
  return response;
void setup()
  dht.begin();
  delay(10);
  Serial.println("Setting up mesh node...");
  /* Initialise the mesh node */
  mesh_node.begin();
void loop()
  /* Accept any incoming connections */
  mesh_node.acceptRequest();
  /* Scan for other nodes and send them a message */
  char request[60];
  sprintf(request, "Temperature read %d celcius from WSN Sensor Node ID %d.", temp, ESP.getChipId());
  mesh_node.attemptScan(request);
  delay(1000);
and for WSN robot code
#define led D1
int temp;
  char response[60];
  sprintf(response, "Temperture data sent %dx for WSN Robot Node ID %d.", response_i++, ESP.getChipId() );
  return response;
void setup()
  delay(10);
  mesh_node.begin();
  pinMode(led, OUTPUT);
void loop()
  char request[60];
  sprintf(request, "Temperature data %d celcius from WSN Sensor Node ID %d.", temp, ESP.getChipId());
  Serial.print(temp);
  Serial.println(" celcius");
  if (temp >= 33)
    digitalWrite(led, HIGH);
    digitalWrite(led, LOW);
  delay(1000);
the serial monitor capture was
received: Temperature reading 26 celcius from WSN Sensor Node ID 13329Ô ÿ??
0 celcius
0 celcius
0 celcius
received: Temperature reading 26 celcius from WSN Sensor Node ID 13329¼ ÿ??
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
0 celcius
received: Temperature reading 26 celcius from WSN Sensor Node ID 13329,ÿ??
0 celcius
0 celcius
0 celcius
0 celcius
received: Temperature reading 26 celcius from WSN Sensor Node ID 13329ÿ??
0 celcius
0 celcius
i had weeks trying to solve it, still no progress
any comment and help would be appriciate
By alvaroxramos
#80736 #include <ESP8266WiFi.h>
#include "DHT.h"
#define DHTPin D4
int temp, humid;
// Read Temperature
Serial.print(temp);
char response[60];
sprintf(response, "Temperature send %d for WSN Robot Node ID %d.",temp );
return response;
void setup()
dht.begin();
delay(10);
mesh_node.begin();
void loop()
char request[60];
sprintf(request, "Temperature read %d celcius from WSN Sensor Node ID %d.",temp + ESP.getChipId());
delay(1000);
