By nonokunono
#15252 An update :
We used ESP-12 with the Lua firmware to write a simple program that puts the chip into sleep mode and wake
up every 90 seconds to send out probe requests (just do an SSID scan).
Using 2 AA batteries that started out at 2.9V in series (lets assume they only have 2000 mAh) in series, this setup lasted a total of 27 days , which amounts
to about 75 mAh per day. The terminal voltage of the 2AA batteries in series is less than 1.8V , at this level the chip cannot successfully power on.
If we equip the setup with 2x D cells (around 15,000 ~ 18,000 mAh) this setup could run up to 9, 10 months depending on the type of D cell.
By plucker
#15373 Hi Nonokunono,
Can you tell me which version on lua firmware you are using for this test?
I have noticed some wake up issue when going to deep sleep mode, and I am using now a c compiled firmware to do the deep sleep.
Thanks and regards,
Plucker
