Re: new opensource firmware
Posted: Wed Jan 31, 2018 2:59 am
No problem. It's been a long time since I've used the Arduino IDE but the problems you're seeing are the same ones that I'd expect anyone to see at initial setup time regardless of dev environment. These are library reference / path issues.
You guessed right with this latest one - setSyncProvider is a function defined in the PaulStoffregen/Time library in Time.cpp on line #312:
https://github.com/PaulStoffregen/Time/ ... e.cpp#L312
I've just pulled the latest from github for the time library and verified that iD8266 builds successfully with that here and it does so I'm fairly sure this build error is an Arduino IDE library reference / path issue to Time.h and Time.cpp
