By Pietrogramma
#93683 Hi everyone, at home I have four sonoff with tasmota firmware, that I use to control four differents light points.
I bought on aliexpress a TTP229 Capacitive Touch Sensor Module and I would like to use it with an ESP8266 to make a remote control with which to control via wifi the sonoff, do you think it is possible to do so? I would like to make a kind of numeric keypad in which each key turns on or off a light point (see attach).
Thanks and ciao
By Pietrogramma
#93699
rpiloverbd wrote:TTP229 Capacitive Touch Sensor Module is compatible with ESP8266. So, I see no problem in implementing your project.
Thanks for your reply, I'm newbie, can you tell me how I can control the sonoff with esp? in the esp that firmware I must use? you know where I can found a tutorial?
Thanks and ciao
