By simplesi
#30439 I'm trying to make a standalone cheerlights receiver using NodeMCU instead of a RaspberryPi (as it will be a lot cheaper :)
I've put together this code to read one of the cheerlights feeds
http://api.thingspeak.com/channels/1417 ... /last.json
but I'd like to make it poll every 60 secs and I'm just going around in circles trying to understand how to do this
Can anyone help please?
Simon
Code: Select all-- get current cheerlights colour
print("Setting the device up as a STATION")
wifi.setmode(wifi.STATION)
print("Connecting to the AP")
wifi.sta.config("CYCY", "")
wifi.sta.connect()
print("Waiting a little bit to get an IP address...")
function main()
    sk=net.createConnection(net.TCP, 0)
    sk:on("receive", function(sck, c)
        field2 = string.find(c, 'field2')
        if field2 ~= nil then
            pkt = string.sub(c,field2 + 10,field2 + 15)
            print ("pkt:" .. pkt)
    end )
    sk:connect(80,"144.212.80.11")
    sk:send("GET /channels/1417/field/2/last.json HTTP/1.1\r\nHost: api.thingspeak.com\r\nConnection: keep-alive\r\nAccept: */*\r\n\r\n")
tmr.alarm(1, 1000, 1, function()
   if wifi.sta.getip()=="0.0.0.0" or wifi.sta.getip() == nil then
      print("Connect AP, Waiting...")
      print("Wifi AP connected. Wicon IP:")
      print(wifi.sta.getip())
      main()
      tmr.stop(1)
end)
By simplesi
#30457 As I was waiting for my post to be approved - I came up with a working method :)
conn = ""
wifi.sta.connect()
function main()
    conn = sk
    end )
      main()
      tmr.stop(1)
end)
tmr.alarm(2, 60000, 1, function()
    conn:send("GET /channels/1417/field/2/last.json HTTP/1.1\r\nHost: api.thingspeak.com\r\nConnection: keep-alive\r\nAccept: */*\r\n\r\n")
end)
