By GengusKahn
#32918 This is a version of the WEB Text to LCD using the SPIFFS to filter via String manipulation very simply.....There are more efficient way's but this is so simple to use for not only the LCD but increase the field size and interact with the "Running Sketch"......
This is the base snippets to allow incorporating into any sketch All declarations need to be made previously e.g. Strings......
If the Webpage files are KEPT below 2KB then there is no need to chop them up to send, just save the file in 2KB chunks...index1.htm, index2.htm etc.....then send each file consecutively......
Using lots of SPIFFS but virtually no memory or sketch space.....
The LCD is driven via Level shifters on GPIO 4 and 5, using the Standard Arduino Libraries and the ESP8266 Latest release, I have not included any of this to allow this to be used on even the -01 with limited I/O.....
The Webpage action....
Code: Select all// /ajax_inputs&L1=123456789&L2=&nocache=968337.7823963541 This is the returned data  "123456789" on line 1 "" line 2
   if (sPath.startsWith("/ajax_inputs&L1="))  // get request.....
     tmtxt1="";
     tmtxt2="";
    got_text = true;                    // print the received text to the LCD if found
File temptext = SPIFFS.open("/temp.txt", "w");
  if (temptext) {
    temptext.print(sPath);
    temptext.close();
    delay(1);
    else {
      lcd.clear();
      lcd.print("rOr Temp.TXT");
      delay(10000);
    File in = SPIFFS.open("/temp.txt", "r");
     in.setTimeout(0);
       Dtmtxt = in.readStringUntil('=');
       tmtxt1 += in.readStringUntil('&');
       tmtxt2 += in.readStringUntil('&');
     in.close();
       tmtxt1.replace("%20", " ");
       tmtxt2.replace("%20", " ");
        lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print(tmtxt1);
        lcd.setCursor(0, 1);
        lcd.print(tmtxt2);
      delay(3000);
The LCD Webpage loader.....
Code: Select all if (sPath.startsWith("/lcd"))
                           // send rest of HTTP header
                        client.println("HTTP/1.1 200 OK");
                        client.println("Content-Type: text/html");
                        client.println("Connection: keep-alive");
                        client.println();
                        // send web page
                      File webFile = SPIFFS.open("/index1.htm", "r");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.print(webFile.readString()); // send web page to client
                            webFile.close();
Finally the Webpage....Place this in the SPIFFS using FS Tool, name this index1.htm
Code: Select all<!DOCTYPE html>
<html lang="en">
    <head>
        <meta charset="utf-8">
        <title>Environment Monitor Text to LCD</title>
        <script>
        strLine1 = "";
        strLine2 = "";
        function SendText()
            nocache = "&nocache=" + Math.random() * 1000000;
            var request = new XMLHttpRequest();
            strLine1 = "&L1=" + document.getElementById("txt_form").line1LCD.value;
            strLine2 = "&L2=" + document.getElementById("txt_form").line2LCD.value;
            request.open("GET", "ajax_inputs" + strLine1 + strLine2 + nocache, true);
            request.send(null);
        </script>
  <body>
<h1>Environment Monitor<BR>LCD Text Input</h1>
<BR><a href="/graph">Sensor Graph Page</a><BR><a href="/">Sensor Gauges Page</a><BR><a href="/table">Datalog Table Page</a><BR><a href="/diag">Diagnostics Information Page</a><BR>
    <body onload="GetESP8266IO()">
       <h1><FONT SIZE=-1>Enter text to send to ESP8266 LCD:</h1>
        <form id="txt_form" name="frmText">
            <label>Line 1: <input type="text" name="line1LCD" size="16" maxlength="16" /></label><br /><br />
            <label>Line 2: <input type="text" name="line2LCD" size="16" maxlength="16" /></label>
        </form>
        <br />
        <input type="submit" value="Send Text" onclick="SendText()" />
<font color="#000000"><body bgcolor="#d0d0f0"><meta name="viewport" content="width=device-width, initial-scale=1.0, user-scalable=yes"><BR>LCD Text Input<BR>
<div style="clear:both;"><FONT SIZE=-1>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With 1602 I2C LCD, DS1307, BMP180 and 2 DHT11 Peripherals Logging to SPIFFS<BR>Compiled using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR></body></html>
This is an Affenpinscher......can't be tooo serious.......
Code: Select all ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
[youtube]
https://www.youtube.com/embed/j8aT7JDh2sU
[/youtube]
By GengusKahn
#47678 Hi there, I have included a working sketch....
Code: Select all/*---------------------------------------------------
                 _____
          _-_-_-_ *|* _-_-_-_
         -_-_-_-_-\@/-_-_-_-_-
__________________________________________________________________________________________________
......Use 5v to 3v Level Shifters as 5V devices like PIR and HC-SR04 can damage your device.......
 ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
#include "FS.h"
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to YOUR LCD ADDRESS !!!
// WiFi connection
const char* ssid = "YourSSID";
const char* password = "YourPassword";
String emailbutton = "off";
String lastdata;
String DsTable;             //Discarded parts if the Strings......
String tmtxt1;              //Strings from the Web....
String tmtxt2;
String stheDate;            //System Start Time...
String theDate;             // The current TimeStamp from Google....
boolean got_text = false;   //Print the Text to LCD if true......
unsigned long ulReqcount;                            // how often has a valid page been requested
unsigned long ulReconncount;                         // how often did we connect to WiFi
unsigned long Dfsize;                                // size of the datalog file
ADC_MODE(ADC_VCC);
// needed to avoid link error on ram check
extern "C"
#include "user_interface.h"
// Create an instance of the server on Port 80-89 = Sensor 1 - 10
WiFiServer server(80);
WiFiClient client;
void wsysreset()
  //Perform challenge to user before getting here to reboot !!!
  //Make an attempt to send mail or other backup of log files then reboot
    ESP.restart();
// the setup routine
void setup()
  Wire.begin();
  // setup globals
  pinMode(0, INPUT);  //Use the Flash Button.........to send email etc.......
  // initialize the lcd
  lcd.init();
  lcd.backlight();
  lcd.print("SensorInit Begin");
  delay(1000);
  // initialize the SPIFFS
  if (!SPIFFS.begin()) {
       lcd.print("SPIFFSinitFailed");
       while(1);
  // clear any old data....
     if (!SPIFFS.format()) {
      lcd.print("format failed");
      while(1);
  lcd.print("Sensor Init Done");
  delay(250);
  // inital connect
  WiFi.mode(WIFI_STA);
  delay(1000);
    // Connect to WiFi network
  lcd.clear();
  lcd.print("Connecting to ");
  lcd.print(ssid);
  delay(1000);
  WiFi.begin(ssid, password);
    lcd.print(".");
  server.begin();
// (re-)start WiFi
void WiFiStart()
  lcd.clear();
  lcd.print(ssid);
    lcd.print(".");
  lcd.clear();
  lcd.print("WiFi connected");
  // Start the server
  server.begin();
  lcd.print("Server started");
  lcd.clear();
  lcd.print("Network Started ");
  // Print the IP address
  lcd.print("IP= ");
  lcd.print(WiFi.localIP());
  lcd.clear();
  lcd.print("Monitor");
  lcd.setCursor(0,1);
  lcd.print(theDate);
// create HTTP 1.1 header
String MakeHTTPHeader(unsigned long ulLength)
  String sHeader;
  sHeader  = F("HTTP/1.1 200 OK\r\nContent-Length: ");
  sHeader += ulLength;
  sHeader += F("\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n");
  return(sHeader);
// make html footer
String MakeHTTPFooter()
  String sResponse;
  sResponse  = F(" ");
  sResponse += F("<BR>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With LCD<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015</body></html>");
  return(sResponse);
// main loop
void loop()
  // check if WLAN is connected
  if (WiFi.status() != WL_CONNECTED)
    WiFiStart();
  if (!client)
    return;
  unsigned long ultimeout = millis()+250;
  while(!client.available() && (millis()<ultimeout) )
    delay(1);
  if(millis()>ultimeout)
    return;
  String sRequest = client.readStringUntil('\r');
  client.flush();
  // stop client, if request is empty
  if(sRequest=="")
    client.stop();
    return;
  // get path; end of path is either space or ?
  // Syntax is e.g. GET /?show=1234 HTTP/1.1
  String sPath="",sParam="", sCmd="";
  String sGetstart="GET ";
  int iStart,iEndSpace,iEndQuest;
  iStart = sRequest.indexOf(sGetstart);
  if (iStart>=0)
    iStart+=+sGetstart.length();
    iEndSpace = sRequest.indexOf(" ",iStart);
    iEndQuest = sRequest.indexOf("?",iStart);
    // are there parameters?
    if(iEndSpace>0)
      if(iEndQuest>0)
        // there are parameters
        sPath  = sRequest.substring(iStart,iEndQuest);
        sParam = sRequest.substring(iEndQuest,iEndSpace);
        // NO parameters
        sPath  = sRequest.substring(iStart,iEndSpace);
  // format the html response
  String sResponse,sResponse2,sHeader;
  //  Update LCD with text from Web
  //_________________________________________________________________
  // /ajax_inputs&L1=123456789&L2=abcdefghi&nocache=968337.7823963541
  //  1-9 on Line 1 and a - i on line 2
     ulReqcount++;
     tmtxt1="";
     tmtxt2="";
File in = SPIFFS.open("/temp.txt", "w");
  if (in) {
    in.print(sPath);
    in.close();
    else {
      lcd.clear();
      while(1);
     in.setTimeout(0);
String Dtmtxt = in.readStringUntil('=');
     in.close();
        lcd.clear();
        lcd.print(tmtxt1);
        lcd.print(tmtxt2);
  // format the html page for gauges
 if(sPath=="/")
    ulReqcount++;
    sResponse  = F("<html>\n<head>\n<title>Web Monitor Text to LCD</title>\n<script>\n\n");
    sResponse += F("strLine1 = \"\";\nstrLine2 = \"\";\n\nfunction SendText()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\n\nstrLine1 = \"&L1=\" + document.getElementById(\"txt_form\").line1LCD.value;\nstrLine2 = \"&L2=\" + document.getElementById(\"txt_form\").line2LCD.value;\n\n");
    sResponse += F("request.open(\"GET\", \"ajax_inputs\" + strLine1 + strLine2 + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>Web Monitor<BR>LCD Text Input</h1>\n");
    sResponse += F("<BR><a href=\"/\">Text Input Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR>\n");
    sResponse += F("<body onload=\"GetESP8266IO()\">\n<h1><FONT SIZE=-1>Enter text to send to ESP8266 LCD:</h1>\n<form id=\"txt_form\" name=\"frmText\">\n<label>Line 1: <input type=\"text\" name=\"line1LCD\" size=\"16\" maxlength=\"16\" /></label><br /><br />\n<label>Line 2: <input type=\"text\" name=\"line2LCD\" size=\"16\" maxlength=\"16\" /></label>\n");
    sResponse += F("</form>\n<br />\n<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\" />\n\n");
    sResponse2 = F("<font color=\"#c0ff84\"><body bgcolor=\"#c384ff\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><BR>LCD Text Input<BR>\n");
    sResponse2 += F("</div>\n<div style=\"clear:both;\"></div><p>");
    sResponse2 += MakeHTTPFooter().c_str();
        // Send the response to the client
    client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()).c_str());
    client.print(sResponse);
    client.print(sResponse2);
  else if(sPath=="/yfireset")
    ulReqcount++;
                                client.println("Connection: close");
                                client.println();
                                client.println("<!DOCTYPE HTML>");
                                client.print("<html><head><title>Web Monitor</title></head><body>");
                                client.print("<font color=\"#c0ff84\"><body bgcolor=\"#c384ff\">");
                                client.print("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
                                client.print("<h1>Web Monitor<BR>WiFi Reset Page </h1>");
                                client.print("<BR><a href=\"/\">Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print(ulReconncount);
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With LCD<BR>");
                                client.print("<FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                client.println("<IMG SRC=\"https://raw.githubusercontent.com/genguskahn/ESP8266-For-DUMMIES/master/SoC/DimmerDocs/organicw.gif\" WIDTH=\"250\" HEIGHT=\"151\" BORDER=\"1\"></body></html>");
  WiFiStart();
  else if(sPath=="/diag")
     float   servolt1 = ESP.getVcc();
     long int spdcount = ESP.getCycleCount();
     delay(1);
     long int spdcount1 = ESP.getCycleCount();
     long int speedcnt = spdcount1-spdcount;
     FlashMode_t ideMode = ESP.getFlashChipMode();
     ulReqcount++;
File logF = SPIFFS.open("/humidlog.CSV", "r");
     Dfsize = logF.size();
                                String duration1 = " ";
                                int hr,mn,st;
                                st = millis() / 1000;
                                mn = st / 60;
                                hr = st / 3600;
                                st = st - mn * 60;
                                mn = mn - hr * 60;
                                if (hr<10) {duration1 += ("0");}
                                duration1 += (hr);
                                duration1 += (":");
                                if (mn<10) {duration1 += ("0");}
                                duration1 += (mn);
                                duration1 += (":");
                                if (st<10) {duration1 += ("0");}
                                duration1 += (st);
                                client.println();
                                client.print("<h1>Web Monitor<BR>SDK Diagnostic Information</h1>");
                                client.print("<BR><a href=\"/\">Monitor LCD Text Input Page</a><BR>Restarted WiFiConnections = ");
                               String diagdat="";
                                diagdat+=ulReconncount;
                                diagdat+="<BR>  Web Page Requests = ";
                                diagdat+=ulReqcount;
                                diagdat+="<BR>  WiFi Station Hostname = ";
                                diagdat+=wifi_station_get_hostname();
                                diagdat+="<BR>  Free RAM = ";
                                client.print(diagdat);
                                client.print((uint32_t)system_get_free_heap_size()/1024);
                                diagdat=" KBytes<BR>  Logged Sample Count = n/a";
//                                diagdat+=ulMeasCount;
                                diagdat+="<BR>  Total Sample points in 24 Hours = 1440<BR>  Minimum Sample Logging Interval = 1 Minutes<BR>  SDK Version = ";
                                diagdat+=ESP.getSdkVersion();
                                diagdat+="<BR>  Boot Version = ";
                                diagdat+=ESP.getBootVersion();
                                diagdat+="<BR>  Free Sketch Space  = ";
                                diagdat+=ESP.getFreeSketchSpace()/1024;
                                diagdat+=" KBytes<BR>  Sketch Size  = ";
                                diagdat+=ESP.getSketchSize()/1024;
                                diagdat+=" KBytes<BR>";
                                client.printf("  Flash Chip id = %08X\n", ESP.getFlashChipId());
                                client.print("<BR>");
                                client.printf("  Flash Chip Mode = %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
                                diagdat="<BR>  Flash Size By ID = ";
                                diagdat+=ESP.getFlashChipRealSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Size (IDE) = ";
                                diagdat+=ESP.getFlashChipSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Speed = ";
                                diagdat+=ESP.getFlashChipSpeed()/1000000;
                                diagdat+=" MHz<BR>  ESP8266 CPU Speed = ";
                                diagdat+=ESP.getCpuFreqMHz();
                                diagdat+=" MHz<BR>";
                                client.printf("  ESP8266 Chip id = %08X\n", ESP.getChipId());
                                diagdat="<BR>  System Instruction Cycles Per Second = ";
                                diagdat+=speedcnt*1000;
                                diagdat+="<BR>  Last System Restart Time = n/a";
//                                diagdat+=MyNtP;
                                diagdat+="<BR>  Last System Restart Reason = ";
                                diagdat+=ESP.getResetInfo();
                                diagdat+="<BR>  System Time = n/a";
//                                diagdat+=TMnow;
                                diagdat+=" (Last Recorded Sample Time)<BR>  System VCC = ";
                                diagdat+=servolt1/1000, 3;
                                diagdat+=" V <BR>  Datalog File Size in Bytes = ";
                                diagdat+=Dfsize;
                                diagdat+="<BR>  System Uptime =";
                                diagdat+=duration1;
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 Sensor & LCD<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                diagdat="";
   else if(sPath=="/srestart")
                                client.println();
                                client.print("<h1>Web Monitor<BR>Please wait 10 Seconds......<BR><FONT SIZE=+2>System Reset Page !!!! </h1>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print("<BR><BR><BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 Sensor & LCD<BR>");
client.stop();
wsysreset();
// 404 for non-matching path
    sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server, What did you sk for?.</p></body></html>";
    ulReqcount++;
    sHeader  = F("HTTP/1.1 404 Not found\r\nContent-Length: ");
    sHeader += sResponse.length();
    client.print(sHeader);
  // and stop the client
  client.stop();
By varind
#54974 I have created a project that takes specific parts of a webpage and posts them to an LCD. The project lets you easily define what to search for, layout on the LCD, and even supports a large font size. I hope you find it useful.
Project Page:
http://www.variableindustries.com/web-to-lcd-2/
Github:
https://github.com/varind/ESP8266-Web-To-LCD
