By nimaaryamehr
#68733 I would like to use this code to use the BotTelgram notifier, but it makes a mistake when compiling؟؟؟
Source:http://telegramiotbot.com/
Code: Select all#include <Arduino.h>
const byte interruptPin = 2;
const char[] SSID="YOUR WIFI SSID";
const char[] PASSWORD="YOUR WIFI PASSWORD";
const char[] BASEURI="http://telegramiotbot.com/api/notify?token=";
const char[] TOKEN_NOTIFY="YOUT TOKEN";
bool interrupted=false;
    interrupt handler
void inputChanged(){
    interrupted=true;
void notify(const char* token){
    HTTPClient http;
    Serial.print("[HTTP] begin...\n");
    http.begin(BASEURI+token);
    Serial.print("[HTTP] GET...\n");
    int httpCode = http.GET();
    if(httpCode) {
        Serial.printf("[HTTP] GET... code: %d\n", httpCode);
    } else {
        Serial.print("[HTTP] GET... failed, no connection or no HTTP server\n");
bool connect(){
    WiFi.begin(SSID,PASSWORD);
    Serial.print("[Connecting]");
    int tries=0;
        Serial.print(".");
        tries++;
        if (tries > 30){
            Serial.print("[connecting failed]");
            return false;
    Serial.print("You're connected to the network");
    return true;
    conect();
    pinMode(interruptPin, INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(interruptPin), inputChanged, FALLING);
    if(interrupted){
        if((WiFi.status() == WL_CONNECTED)) {
            notify(TOKEN_NOTIFY);
            interrupted=false;
By schufti
#68737 try this. I don't know if it works but it compiles ...
const char* SSID="YOUR WIFI SSID";
const char* PASSWORD="YOUR WIFI PASSWORD";
const char* BASEURI="http://telegramiotbot.com/api/notify?token=";
const char* TOKEN_NOTIFY="YOUT TOKEN";
    interrupt handler
    interrupted=true;
    HTTPClient http;
    http.begin(String(BASEURI) + token);
    if(httpCode) {
    } else {
bool connect(){
    int tries=0;
        Serial.print(".");
        tries++;
        if (tries > 30){
            return false;
    return true;
    connect();
    if(interrupted){
            interrupted=false;
