By Momo06
#70489 Hi,
I m doing an IOT thermostat.
Code: Select allWiFiServer server(80);
void setup()
  initHardware();
  setupWiFi();
  server.begin();
void loop()
  thermostat();
  if (!client) {
    return;
void thermostat(){
//checking if the actual temperature is not higher than the temperature sets by the user. If so, heating start through a rele
I would like to update temperature value while there is no client connected. I make a thermostat() function called in the loop before creating WifiClient object. But the AP wifi doesn t show up or it s impossible to get connected to it.
I checked over the internet during hours whitout success.
I could called thermostat() function in setup and doing a ESP.reset() when there is no client connected but it s so dirty.
Any held would be appreciate
Thanks
Morgan
