By 95tinu
#11716 hello,
I want to scan all available APs, So im calling wifi_station_scan(&config,scan_done).
and in config struct all variable I am putting NULL , bcoz in SDK development document I studied if config=NULL ,then only it will scan all available APs,
but this wifi_station_scan() function every time returning FAIL.(means every time its getting fail ).
and I have no idea why its happening like that?
please help me :) :)
Thank you !
herr I am putting my code is anything wrong?
* FunctionName : user_init
* Description : entry of user application, init user function here
* Parameters : none
* Returns : none
void user_init(void)
config.ssid = NULL;
config.bssid = NULL;
config.channel = 0;
bool chat=0;
uint8 ch;
os_printf("SDK version:%s\n", system_get_sdk_version());
// wifi_station_scan(NULL,scan_done);
// scan_done;
os_printf("before wifi get mode\n");
// wdt_feed();
os_printf("mode=%u\n",wifi_get_opmode());
os_printf("set mode=%u\n", wifi_set_opmode(STATION_MODE));
os_printf("mode_afterset=%u\n",wifi_get_opmode());
os_printf("scan_result=%u\n",wifi_station_scan(NULL,scan_done));
if(wifi_station_scan(&config, scan_done))
os_printf("chat=%c\n sid=%s\n bsid=%s\n ch=%d \n",chat,config.ssid,config.bssid,config.channel);
// specialAtState = FALSE;
os_printf("sucess\n");
// at_backError;
os_printf("\r\nERROR\r\n");
// scan_done(&arg,stat);
static void ICACHE_FLASH_ATTR
scan_done(void* arg,STATUS status)
os_printf("enter_scan\n");
uint8 ssid[33];
char temp[128];
if (status == OK)
struct bss_info *bss_link = (struct bss_info *)arg;
bss_link = bss_link->next.stqe_next;//ignore first
while (bss_link != NULL)
os_memset(ssid, 0, 33);
if (os_strlen(bss_link->ssid) <= 32)
os_memcpy(ssid, bss_link->ssid, os_strlen(bss_link->ssid));
os_memcpy(ssid, bss_link->ssid, 32);
os_sprintf(temp,"+CWLAP:(%d,\"%s\",%d,\""MACSTR"\",%d)\r\n",
bss_link->authmode, ssid, bss_link->rssi,
os_printf("info=%s\n",temp);
//at_backOk;
os_printf("\nOK\n");
os_printf("\nERROR\n");
//at_backError;
// specialAtState = TRUE;
// at_state = at_statIdle;
AND OUTPUT:
ets Jan 8 2013,rst cause:2, boot mode:(3,3)
load 0x40100000, len 25616, room 16
tail 0
chksum 0xd1
load 0x3ffe8000, len 2500, room 8
tail 12
chksum 0x5b
ho 0 tail 12 room 4
load 0x3ffe89d0, len 1100, room 12
tail 0
chksum 0x54
csum 0x54
SDK ver: 0.9.5 compiled @ Jan 23 2015 20:38:12
phy ver: 313, pp ver: 8.0
SDK version:0.9.5
mode=1
set mode=1
mode_afterset=1
scan_result=0
ERROR :roll: :roll:
By greggl
#11906 You're not alone -- I've been struggling with the exact same problem all day! I also started with the same code routine you pulled from the SDK AT files. I've tried adding start up delays, using different values for wifi_set_opmode, scanning for a single channel, rather than all channels -- all with a FALSE return from wifi_station_scan.
Does anyone have this working? An example of code that does work would be greatly appreciated!
By scargill
#32925 HI
This just doesn't work...
I fixed the missing ) in the first function - but the config struct - which already exists apparently - I does not appear to have SSID as a member.... anyone have any joy with this? Or am I missing something?
