By UniqueIdentifier
#45544 Disregard. I can see now that it takes a lot more work on the client side. In fact, I think it over complicates what needs to be done.
Why not just allow the use to make a button, graph, gauge, etc and read the value as a number, % or whatever it is since you are storing those messages or updating the dashboard anyways.
By 4refr0nt
#48520
smartman2012 wrote:This Sketch doesn't compile with current version of PubSubClient library. API has changed significantly. Are you planning an update? Thanks.
I'm use PubSubClient v1.99.1 from Imroy https://github.com/Imroy/pubsubclient
(Arduino IDE included as default different PubSubClient lib from knolleary https://github.com/knolleary/pubsubclient/)
By daxkamala
#51583 Hi, I've spent a couple of hours now trying to connect the app to CloudMQTT without success.
Same trying to connect to a local Mosquitto.
Log says 'Client offline(MQTT)' then 'Client Closed'
Have tried every combination of settings based on your nice easy start guide.
Any ideas please?
