Page 3 of 4
Re: RESET and CHIP_EN pins - instability
PostPosted: Thu Jun 25, 2015 12:44 pm
by j0hncc
Wow how frustrating!
I have used maybe a dozen ESP-01s and several ESP-12's and never had any do this.
I did fry a couple of them but it was through my own mistake :)
Good luck,
John
PostPosted: Thu Jun 25, 2015 1:20 pm
by kriegste
This sounds like a latch-up-effect
https://en.wikipedia.org/wiki/Latchup
Can you rule ESD out? You could try to include some zener diodes (3V6) in your circuit.
PostPosted: Thu Jun 25, 2015 1:52 pm
by tytower
kenn wrote:
martinayotte wrote:
Just as an aid perhaps, I connect both pins to high direct . Have not bothered to implement any resistors yet .
That is not a good practice on "undetermined I/O state", it is only good and it is "known Input Only".
It's guaranteed that RESET and CHIP_EN pins are inputs when the ESP8266 is first powered up, so as long as the user code doesn't ever make them outputs, shorting them to high shouldn't cause a problem.
Kenn, can you tell me where I might find some detail about this please?
PostPosted: Thu Jun 25, 2015 2:02 pm
by kenn
tytower wrote:
kenn wrote:It's guaranteed that RESET and CHIP_EN pins are inputs when the ESP8266 is first powered up, so as long as the user code doesn't ever make them outputs, shorting them to high shouldn't cause a problem.
Only that it must be true since CHIP_EN is always read at startup, right? And RESET must expect to be hit at any time...
I do note that according to this hardware doc, the 'official' ESP8266 evaluation board uses a 5k pullup on CHIP_EN and 50 ohms in series with the reset switch and ground.
