By crosofg
#53869 Hello
I got this led bulb which contains ESP8266. It used to work previously. All of sudden its not making Wifi Accces Point. Further more it is not discovering other access point as well.
I am able to run local codes in the esp. Everything is working fine. I am able to flash it as well. But the Wifi part is not functioning. There are however no errors thrown. It is simply behaving as if no wifi Access point is present.
Please see the attached image.
By Orcanbull
#53998 Time to buy a new one,
I had this aswell , the Code will run, however when you perform a scan no WIFI SSID's are shown,
Is the module getting warm? When i measured though everything i found something to be different with the antenna part, so i guessed a burned part or something.
