Re: ESP-07 questions (antenna & breakout board)
Posted: Tue Mar 28, 2017 2:42 am
rudy wrote:alex_g wrote:1) The ESP-07 has two antennae, the on-board ceramic one and the receptacle for the external one. Are these two DESIGNED to work together?
They are not designed to work together. Just because it works does not mean it is working properly. I have a ESP-07S and I can use it without an antenna. (it does not include the antenna like the ESP-07) It works. But of course it has less signal for transmit and receive.
If you are using the external antenna with the ESP-07 then you should remove the shorting resistor that brings the connection to the on board antenna.
Thanks very much rudy, that's kind of what I thought, but it's nice to have it confirmed by someone who really knows.
Just to be 100% sure, the resistor you mention is the one between the external antenna jack and the red LED, yes? That is, NOT the one between the red and the blue LEDs, hope I've got that right! (BTW, nice to know that you can disconnect the on-board ceramic one so easily - and reversibly)
