Re: ESP-01 resets when switching relay board
Posted: Wed Jul 20, 2016 3:43 pm
Xalil Laleh wrote:I'm using ESP-01 with relay connected to 230V bulb and I have the reset issue.
Also read this long forum and almost implemented any solution. But still the problem is here.
I even cut the reset pin, but nothing achieved!
I have to tell you there is no absolute solution for this problem here and all solutions worked in their specific environment and they are not in general.
I read somewhere ESP-XX is not for product environment and just for Hobby.
I already bought 50 pcs and I have a plan for a product. Now I feel, I lost my money for this weak so-called WiFi module!
BTW any help appreciated...
Hi, OK it appears you have given up and lost your money.
Or you could post a schematic and see if we can help.
With regard to:
That issue was quite some time ago and only applied to the blue ESP8266-01s, it was addressed on the black PCBs.
SSRs are always a better option with the ESPs but if you realy have to switch with a relay there are some tricks that help:
Opto couple the output.
If you know the switching time (if you don't you can measure it) and then try to switch the relay as close to the Zero cross point as possable to reduce interferance, are two that come to mind.
