By Eddiie
#7917
tprochazka wrote:GPIO0 is connected directly to 3V3 pin, it is not easy to cut it. Where exactly you made it?
download/file.php?id=22&mode=view
I thought the chip had pins to lift up, not underneath (bottom mount?). I then tried removing the chip to re-flash but got board too hot and all the other pieces came off.
What is the yellow circle on the ESP8266 chip schematics? (link above) Is it representing pin 1?
By gwizz
#7964
Eddiie wrote:I tried different speeds - 300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200,230400, some higher all spit out garbage!!
Have you tried 74880 baud - some firmware gives boot information at this speed apparently?
By Eddiie
#7966
It turned out to be 57000 baud. :)
