By Atlantis
#20978 What is a proper way to reset ESP8266 module? Should I use RST o CH_PD pin? Both of them connected to GND perform reset, but if I use RST, message "MEM CHECK FAIL!!!" appears after boot. It doesn't happen alert using CH_PD. Why?
By tytower
#21001 Thats interesting to know . CH_PD is the enable chip pin I think .On the datasheet it is refered to as CHIP_PD So enable it on or enable it not.
Reset is the full power up thing . I usually just power off and on on the Vcc
