By RedStar
#54536 Take caution with input voltage!
I have a NodeMCU development board (ESP12E) with an CP2102 USB to serial TTL and voltage regulator that only accepts input voltage between 4v and 5.25v. Take a look to its data sheet:
https://www.silabs.com/Support%20Documents/TechnicalDocs/CP2102-9.pdf
In that case you will need a zener diode (for simplicity) to step down from 9v to 4.7v or (best) 5.1v. Remember that voltage difference are consumed by the limiting resistor, so it's best to choose 5,1v zener over 4,7v one:
http://www.electronics-tutorials.ws/diode/diode_7.html
Good luck :)
