So to make it right:
Hello people =D
So to the issue:
I have bought this unit, which I'm happy with. I managed to flash one, and not brick it =) But I think i ruined the antenna.
http://www.dx.com/p/esp-07-esp8266-serial-wi-f-wireless-module-w-built-in-antenna-compatible-with-3-3v-5v-for-arduino-400559#.Vfv6QZedqPW
When i use the AT commands I get the OK. But when I try to search for AP's, both in mode 1 and 3, nothing is listed.
When I put the unit in mode 2, it will not create a visible AP.
Luckily I ordered two units, and as soon as the second unit arrived, I hooked it up and tested it without a firmware update. (SDK 1.1.1(?))
AT says OK
AT+CWLAP perfect
AT+CWJAP perfect
Everything works perfect whit this unit.
As well as the built in antenna, I also have this:
http://www.dx.com/p/2-4ghz-3dbi-wi-fi-antenna-extension-cable-for-esp8266-series-modules-black-golden-379494
it has been connected to the defect unit, but not the working one. I have not dared in case it was the source of the problem.
Does anyone know how i can test the antennas? is there another way to fix this? My there be another problem than the antenna?
One solution is to throw it away, but hey, it's much more fun and frustrating trying to fix stuff, right? =)
PS: Yes i was stupid enough to attach the extra antenna while I had power on the unit.
