Esp8266 GPIO initial Vortage Burst
PostPosted: Fri Oct 16, 2015 1:28 pm
by Jocobes
Hello everybody!
I am currently working on a project where I am using an esp8266-01 to control a relay. However I noticed whenever I restart the esp8266 there's a short voltage burst on rah the gpio0 and the gpio2. This impulse messes with my transistor and screws up my built
Now here's the question: is there any way of blocking that initial burst?
I would appreciate any help!
Thank you in advance.
Jocobes
Re: Esp8266 GPIO initial Vortage Burst
PostPosted: Fri Oct 16, 2015 1:50 pm
by Barnabybear
Hi, the short answer is no (not that I've seen), but there are various workrounds.
Use an ESP variant with more GPIOs.
If you use an led, opto coupler or something like that, connect it to Vcc and take the GPIO low to switch on.
Use low on and high off and invert the GPIO output in some way (a transistor).
PostPosted: Fri Oct 16, 2015 5:56 pm
by xtal
If you are driving the base of xistor thru a resistor , you could put a cap in xistor base to ground,
keep in mind this will delay on/off slightly. [ depends on RC constant and xistor switch point]
Could also use diode/xistor AND gate requiring 2 signals to turn on.....
