By jackyjacques
#35527 Hello,
Is there any known issues in WiFi connection to the Orange Livebox Play ? I can get IP address (static or dynamic) but my ESP8266 (tried several) does not reply to ping. Same devices worked fine wint anotrer ISP box . Also everything is OK when I connect my ESP to a WiFi relay (PC must be also connected to the same relay).
Any idea ?
Thanks in advance.
Jacques
By eduperez
#35575
jackyjacques wrote:
eduperez wrote:Perhaps "wifi isolation" is enabled in that router?
What is "wifi isolation" ?
It's an option on some routers, that isolate wifi devices from each other: you can connect both your ESP and a phone to the same AP, but they do not "see" each other.
