By grandwarden
#37299 i am gettiing following error when trying to compile code
* This sketch sends data via HTTP GET requests to data.sparkfun.com service.
* You need to get streamId and privateKey at data.sparkfun.com and paste them
* below. Or just customize this script to talk to other HTTP servers.
const char* ssid = "CR7";
const char* password = "iamamloneathome";
const char* host = "data.sparkfun.com";
const char* streamId = "XGNmx3D2WjIK8OzwMpOr";
const char* privateKey = "1JA1PmBbnduMgoYdVqox";
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
int value = 0;
delay(5000);
++value;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/input/";
url += streamId;
url += "?private_key=";
url += privateKey;
url += "&value=";
url += value;
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while(client.available()){
Serial.print(line);
output:
warning: espcomm_sync failed
error: espcomm_open failed
By grandwarden
#37475 Thank s for the reply.. That might resolve the issue. Most of the connections and scripts available on the internet are of using arising uno and esp8266 while I am using arduino mega 2560.can you help me out with connections.. I am sharing my connection diagram
