By maxleggieri
#37548 Hi,
Just bought some NodeMCU dev boards... now, i did my setup with Eclipse + mingw + unofficial esp8266 sdk.
My goal is to use the dev board with native c programs discarding lua stuff.
I can import examples, compile them and flash into the module but after flashing the program nothing happens, no output on the COM port... no GPIO working, nothing at all.
I'm i missing something? do i need to configure the prebuilt makefiles in a proper way?
Thanks
Max
By maxleggieri
#37883
flemlion wrote:Sounds like there's a baudrate mismatch
Thanks flemlion, actual i've found that at native speed (74880) i can read this in the serial terminal:
Code: Select allets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 26412, room 16
tail 12
chksum 0xef
ho 0 tail 12 room 4
load 0x33333333, len 858993459, room 12
The problem is that i'm trying to trigger gpio5 LOW and HIGH with a timer, i get no errors but i always read 0v on gpio5 (D1 on my nodemcu v1.0 board
I've also checked the flash addresses and they seems correct...
any ideas?
Max
