By madsci1016
#37669 Has anyone been successful at using the hardware I2S bus for input? I would like to use it to record sound from an I2S microphone and stream the audio overy wifi.
By cnlohr
#41020 ***EDIT*** Don't use the code below, it seems to occasionally crash. I have a much better copy at my github at: https://github.com/cnlohr/esp8266duplexi2s
After 30+ hours of tinkering with all the variables, looking through some ESP32 code, changing values trying to get it working, it looks like I got it.
I have a bit of an unusual initial setup, as I'm sharing the I2S for sending and receiving, in reality, I think it was intended to have separate descriptors for sending/receiving.
Code: Select all//ESP8266 I2S Input+Output
#include "slc_register.h"
#include "mystuff.h"
#include <c_types.h>
#include "user_interface.h"
#include "pin_mux_register.h"
#include <dmastuff.h>
#define DMABUFFERDEPTH 3
#define I2SDMABUFLEN (256)
#define LINE32LEN I2SDMABUFLEN
#define RX_NUM (I2SDMABUFLEN)
#define WS_I2S_BCK 4  //Can't be less than 1.
#define WS_I2S_DIV 4
//I2S DMA buffer descriptors
static struct sdio_queue i2sBufDesc[DMABUFFERDEPTH];
uint32_t i2sBD[I2SDMABUFLEN*DMABUFFERDEPTH];
int fxcycle;
int erx, etx;
LOCAL void slc_isr(void) {
   //portBASE_TYPE HPTaskAwoken=0;
   struct sdio_queue *finishedDesc;
   uint32 slc_intr_status;
   int x;
   fxcycle++;
   slc_intr_status = READ_PERI_REG(SLC_INT_STATUS);
   //clear all intr flags
   WRITE_PERI_REG(SLC_INT_CLR, 0xffffffff);//slc_intr_status);
//printf( "%08x\n", slc_intr_status );
   if ( (slc_intr_status & SLC_RX_EOF_INT_ST))
      finishedDesc=(struct sdio_queue*)READ_PERI_REG(SLC_RX_EOF_DES_ADDR);
      erx++;
   if ( (slc_intr_status & SLC_TX_EOF_INT_ST))
       finishedDesc=(struct sdio_queue*)READ_PERI_REG(SLC_TX_EOF_DES_ADDR);
      //finishedDesc=finishedDesc->next_link_ptr;
      //Don't know why - but this MUST be done, otherwise everything comes to a screeching halt.
      finishedDesc->owner=1;
      etx++;
//Initialize I2S subsystem for DMA circular buffer use
void ICACHE_FLASH_ATTR testi2s_init() {
   int x, y;
   //Bits are shifted out
   //Initialize DMA buffer descriptors in such a way that they will form a circular
   //buffer.
   for (x=0; x<DMABUFFERDEPTH; x++) {
      i2sBufDesc[x].owner=1;
      i2sBufDesc[x].eof=1;
      i2sBufDesc[x].sub_sof=0;
      i2sBufDesc[x].datalen=I2SDMABUFLEN*4;
      i2sBufDesc[x].blocksize=I2SDMABUFLEN*4;
      i2sBufDesc[x].buf_ptr=(uint32_t)&i2sBD[x*I2SDMABUFLEN];
      i2sBufDesc[x].unused=0;
      i2sBufDesc[x].next_link_ptr=(int)((x<(DMABUFFERDEPTH-1))?(&i2sBufDesc[x+1]):(&i2sBufDesc[0]));
      for( y = 0; y < I2SDMABUFLEN; y++ )
         i2sBD[y+x*I2SDMABUFLEN] = 0xAAAAAAAA;
   //Reset DMA )
   SET_PERI_REG_MASK(SLC_CONF0, SLC_RXLINK_RST|SLC_TXLINK_RST|SLC_AHBM_RST | SLC_AHBM_FIFO_RST);
   CLEAR_PERI_REG_MASK(SLC_CONF0, SLC_RXLINK_RST|SLC_TXLINK_RST|SLC_AHBM_RST | SLC_AHBM_FIFO_RST);
   //Clear DMA int flags
   SET_PERI_REG_MASK(SLC_INT_CLR,  0xffffffff);
   CLEAR_PERI_REG_MASK(SLC_INT_CLR,  0xffffffff);
   //Enable and configure DMA
   CLEAR_PERI_REG_MASK(SLC_CONF0, (SLC_MODE<<SLC_MODE_S));
   SET_PERI_REG_MASK(SLC_CONF0,(1<<SLC_MODE_S));
   CLEAR_PERI_REG_MASK(SLC_TX_LINK,SLC_TXLINK_DESCADDR_MASK);
   SET_PERI_REG_MASK(SLC_TX_LINK, ((uint32)&i2sBufDesc[1]) & SLC_TXLINK_DESCADDR_MASK); //any random desc is OK, we don't use TX but it needs something valid
   CLEAR_PERI_REG_MASK(SLC_RX_LINK,SLC_RXLINK_DESCADDR_MASK);
   SET_PERI_REG_MASK(SLC_RX_LINK, ((uint32)&i2sBufDesc[0]) & SLC_RXLINK_DESCADDR_MASK);
   //Attach the DMA interrupt
   ets_isr_attach(ETS_SLC_INUM, slc_isr);
   WRITE_PERI_REG(SLC_INT_ENA,  SLC_INTEREST_EVENT);
   //clear any interrupt flags that are set
   ///enable DMA intr in cpu
   ets_isr_unmask(1<<ETS_SLC_INUM);
   //Start transmission
   SET_PERI_REG_MASK(SLC_TX_LINK, SLC_TXLINK_START);
   SET_PERI_REG_MASK(SLC_RX_LINK, SLC_RXLINK_START);
   //Init pins to i2s functions
   PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, FUNC_I2SI_DATA);
   PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, FUNC_I2SI_WS);  //Dunno why - this is needed.  If it's not enabled, nothing will be read.
   PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0RXD_U, FUNC_I2SO_DATA);
   PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_I2SO_WS);
   PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_I2SO_BCK);
   //Enable clock to i2s subsystem
   i2c_writeReg_Mask_def(i2c_bbpll, i2c_bbpll_en_audio_clock_out, 1);
   //Reset I2S subsystem
   CLEAR_PERI_REG_MASK(I2SCONF,I2S_I2S_RESET_MASK);
   SET_PERI_REG_MASK(I2SCONF,I2S_I2S_RESET_MASK);
   CLEAR_PERI_REG_MASK(I2S_FIFO_CONF, I2S_I2S_DSCR_EN|(I2S_I2S_RX_FIFO_MOD<<I2S_I2S_RX_FIFO_MOD_S)|(I2S_I2S_TX_FIFO_MOD<<I2S_I2S_TX_FIFO_MOD_S));
   SET_PERI_REG_MASK(I2S_FIFO_CONF, I2S_I2S_DSCR_EN);
   WRITE_PERI_REG(I2SRXEOF_NUM, RX_NUM);
   CLEAR_PERI_REG_MASK(I2SCONF_CHAN, (I2S_TX_CHAN_MOD<<I2S_TX_CHAN_MOD_S)|(I2S_RX_CHAN_MOD<<I2S_RX_CHAN_MOD_S));
   //Clear int
   SET_PERI_REG_MASK(I2SINT_CLR,   I2S_I2S_TX_REMPTY_INT_CLR|I2S_I2S_TX_WFULL_INT_CLR|
         I2S_I2S_RX_WFULL_INT_CLR|I2S_I2S_PUT_DATA_INT_CLR|I2S_I2S_TAKE_DATA_INT_CLR);
   CLEAR_PERI_REG_MASK(I2SINT_CLR, I2S_I2S_TX_REMPTY_INT_CLR|I2S_I2S_TX_WFULL_INT_CLR|
   CLEAR_PERI_REG_MASK(I2SCONF, I2S_TRANS_SLAVE_MOD|I2S_RECE_SLAVE_MOD|
                  (I2S_BITS_MOD<<I2S_BITS_MOD_S)|
                  (I2S_BCK_DIV_NUM <<I2S_BCK_DIV_NUM_S)|
                                       (I2S_CLKM_DIV_NUM<<I2S_CLKM_DIV_NUM_S));
   SET_PERI_REG_MASK(I2SCONF, I2S_RIGHT_FIRST|I2S_MSB_RIGHT|
                  I2S_RECE_MSB_SHIFT|I2S_TRANS_MSB_SHIFT|
                  ((WS_I2S_BCK&I2S_BCK_DIV_NUM )<<I2S_BCK_DIV_NUM_S)|
                  ((WS_I2S_DIV&I2S_CLKM_DIV_NUM)<<I2S_CLKM_DIV_NUM_S) );
   //enable int
   SET_PERI_REG_MASK(I2SINT_ENA,   I2S_I2S_TX_REMPTY_INT_ENA|I2S_I2S_TX_WFULL_INT_ENA|
         I2S_I2S_RX_REMPTY_INT_ENA|I2S_I2S_TX_PUT_DATA_INT_ENA|I2S_I2S_RX_TAKE_DATA_INT_ENA);
   SET_PERI_REG_MASK(I2SCONF,I2S_I2S_TX_START|I2S_I2S_RX_START);
