By Trent
#43339 The SSR looks fine as well but I'm still hung up on the forward current issue. It lists 50ma in the datasheet. I still can't understand how that doesn't translate into blowing the GPIO. Sorry for my ignorance :(
By lethe
#43343
Trent wrote:The SSR looks fine as well but I'm still hung up on the forward current issue. It lists 50ma in the datasheet. I still can't understand how that doesn't translate into blowing the GPIO. Sorry for my ignorance :(
50mA is the absolute maximum rating. The output will turn on somewhere between 2-3mA, so calculate the resistor for 5mA and it should work fine.
By jra
#43362 When I got home I took out my Sainsmart 2 channel 5V relay like this one http://www.sainsmart.com/arduino-pro-mini.html and connected it as follows:
VCC to 3.3v
5V through a 9.9 ohm resistor to JD-VCC
Refer to the schematic on the previous link.
Prior to applying power I measured the current limiting opto-isolator resistor R4 (nominally 1K) as 988 ohms. I applied power, grounded IN2, verified the relay closed and made the following measurements:
Voltage across R4: 0.492V
Current through opto-isolator: 0.492V/988 ohms = 0.498ma
Voltage across 9.8 ohm resistor in series with relay coil: 0.434V
Current through relay coil: 0.434V/9.8 ohms = 44.3ma
The Sainsmart spec says each relay requires 15-20ma of current, not sure why this one is pulling double that. More importantly, it only took half a milliamp to turn the opto-isolator on so you should have no problem driving this with the GPIO pins.
