Here we can all chat about fixing the AT+ command structure and the associated responses.
By Patry
#47082 First of all, i am using :
ARD-FTDI-F Serial Adapter 5V / 3.3V Logic levels USB to TTL
ESP8266-12e
Yurobot 3.3V/5V power supply
FTDI ESP
tx rx
rx tx
gnd gnd
and on the ESP
Enable (CH_PH, I believe) -> 3.3V
Vcc -> 3.3V
GPIO15 -> GND
Ive looked into the settings of my FTDI, the baud rate is set to 115200 so is my Serial monitor window setting. I tried changing both to 9600, didnt get me an AT responce
Both are on COM5.
The ESP still flash when I power it on and off ( its not burned )
I cant figure what im doing wrong, anybody has an idea ?
By tsknightstorm
#53247 For me I have exactly the same problem. I try to figure out this now for more than a week.
Setup: I wired up my ESP12F exactly like in "Kolbans book on ESP8266". So every pin should be set correctly to hi or low. For power I use a bred board power supply with an 5V USB Input. The USB power supply and the bred board supply should have enough power for the ESP. Tomorrow i try it with the Labor power supply to be really sure.
Problem: The ESP starts but I can't type in AT-commands. If I press a button on my keyboard, it shows more of this unknown symbols. Is it possible that I got a china’s ESP without the AT Software on it?
Output on UART:
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
  SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
do빹▒r▒▒P▒nN▒
SDK h▒h▒ip▒$x▒▒▒,▒q*Ѫ8▒▒jtN▒
