Questions with regards to ESP8266 Basic and hardware interfacing and control via Basic commands
Moderator: Mmiscool
By Daniel Saiz
#64396 Hi,
Is there any way to reduce the transmission power of the wifi module?
I am trying to integrate the esp8266 into an audio amplifier and I have problems with the interference generated by the module.
Thank you
By bugs
#64401 Hi,
Not really answering the question that you posed (as I don't know if output can be reduced by a command) but the audio amplifier should not be receiving radio frequencies at 2.4 GHz!
Assuming that some part of the amplifier is being swamped by RF then you could first enclose the amplifier pcb or wiring in a metal screening can. It could be pick-up on the input wires to the amplifier (which should be screened cable anyway) - this can be reduced by passing the cable through ferrite beads and/or adding small filter capacitors at the input.
Basically the ESP is doing what it is supposed to do - the amplifier is not.
