AT command interface and "Light sleep" mode ...
Posted: Thu Sep 29, 2016 4:19 pm
Hi, Not sure if this is the correct area for this so please feel free to move it if appropriate
I have an 8266-12E module and have installed the latest AT command code (0.51) and it all works wonderfully in "station mode"
However, the power consumption in the default sleep mode (MODEM SLEEP) is a bit high for my application so I'm looking at "LIGHT SLEEP".
Reading the documentation it implies that both Modem and Light sleep still respond to traffic from the AP but I find this doesn't seem to be the case - In modem sleep it DOES respond but in light sleep it doesn't.
I am aware from other research that an electrical wake via a GPIO pin is needed if you need to issue commands to the 8266 but generally I don't do that except when responding to an incoming HTML request.
Am I missing something fundamental here???
The AT command I/F supports AT+SLEEP=1 - if I do need to wake the 8266 what GPIO pin should I use on the 8266-12E? Is one setup for this purpose by default in the AT command I/F??
My app is a simple web-server and most of the time is spinning awaiting an incoming HTML request.
Are there any tricks or gotchas I should be aware of ??
TIA
Dave
TIA
Dave
