i upload my project with the correct makefiles and script to build. its a webserver with relay, temp sensor, and upload to Azure you can ingnore all of this and only use the makefile and the structure of the proyect.
https://www.dropbox.com/s/zrhcsv3adb8l675/app.rar?dl=0
if you dont want then this is my makefile, its in the root folder app
# Required variables for each makefile
# Discard this section from all parent makefiles
# Expected variables (with automatic defaults):
# CSRCS (all "C" files in the dir)
# SUBDIRS (all subdirs with a Makefile)
# GEN_LIBS - list of libs to be generated ()
# GEN_IMAGES - list of object file images to be generated ()
# GEN_BINS - list of binaries to be generated ()
# COMPONENTS_xxx - a list of libs/objs in the form
# subdir/lib to be extracted and rolled up into
# a generated lib/image xxx.a ()
TARGET = eagle
#FLAVOR = release
FLAVOR = debug
#EXTRA_CCFLAGS += -u
ifndef PDIR # {
GEN_IMAGES= eagle.app.v6.out
GEN_BINS= eagle.app.v6.bin
SPECIAL_MKTARGETS=$(APP_MKTARGETS)
SUBDIRS= \
user \
driver
endif # } PDIR
APPDIR = .
LDDIR = ../ld
CCFLAGS += -Os
TARGET_LDFLAGS = \
-nostdlib \
-Wl,-EL \
--longcalls \
--text-section-literals
ifeq ($(FLAVOR),debug)
TARGET_LDFLAGS += -g -O2
endif
ifeq ($(FLAVOR),release)
TARGET_LDFLAGS += -g -O0
endif
COMPONENTS_eagle.app.v6 = \
user/libuser.a \
driver/libdriver.a
LINKFLAGS_eagle.app.v6 = \
-L../lib \
-nostdlib \
-T$(LD_FILE) \
-Wl,--no-check-sections \
-u call_user_start \
-Wl,-static \
-Wl,--start-group \
-lc \
-lgcc \
-lhal \
-lphy \
-lpp \
-lnet80211 \
-llwip \
-lwpa \
-lcrypto \
-lmain \
-ljson \
-lupgrade\
-lssl \
-lpwm \
-lsmartconfig \
$(DEP_LIBS_eagle.app.v6) \
-Wl,--end-group
DEPENDS_eagle.app.v6 = \
$(LD_FILE) \
$(LDDIR)/eagle.rom.addr.v6.ld
# Configuration i.e. compile options etc.
# Target specific stuff (defines etc.) goes in here!
# Generally values applying to a tree are captured in the
# makefile at its root level - these are then overridden
# for a subtree within the makefile rooted therein
#UNIVERSAL_TARGET_DEFINES = \
# Other potential configuration flags include:
# -DTXRX_TXBUF_DEBUG
# -DTXRX_RXBUF_DEBUG
# -DWLAN_CONFIG_CCX
CONFIGURATION_DEFINES = -DICACHE_FLASH
DEFINES += \
$(UNIVERSAL_TARGET_DEFINES) \
$(CONFIGURATION_DEFINES)
DDEFINES += \
# Recursion Magic - Don't touch this!!
# Each subtree potentially has an include directory
# corresponding to the common APIs applicable to modules
# rooted at that subtree. Accordingly, the INCLUDE PATH
# of a module can only contain the include directories up
# its parent path, and not its siblings
# Required for each makefile to inherit from the parent
INCLUDES := $(INCLUDES) -I $(PDIR)include
PDIR := ../$(PDIR)
sinclude $(PDIR)Makefile
.PHONY: FORCE
FORCE:
and the script to build its like :
#!/bin/bash
echo "gen_misc.sh version 20150511"
echo ""
echo "Please follow below steps(1-5) to generate specific bin(s):"
echo "STEP 1: choose boot version(0=boot_v1.1, 1=boot_v1.2+, 2=none)"
echo "enter(0/1/2, default 2):"
read input
if [ -z "$input" ]; then
boot=none
elif [ $input == 0 ]; then
boot=old
elif [ $input == 1 ]; then
boot=new
boot=none
fi
echo "boot mode: $boot"
echo ""
echo "STEP 2: choose bin generate(0=eagle.flash.bin+eagle.irom0text.bin, 1=user1.bin, 2=user2.bin)"
echo "enter (0/1/2, default 0):"
read input
if [ $boot != none ]; then
boot=none
echo "ignore boot"
fi
app=0
echo "generate bin: eagle.flash.bin+eagle.irom0text.bin"
if [ $boot == none ]; then
app=0
echo "choose no boot before"
app=1
echo "generate bin: user1.bin"
fi
elif [ $input == 2 ]; then
app=0
app=2
echo "generate bin: user2.bin"
fi
boot=none
echo "ignore boot"
fi
app=0
fi
echo ""
echo "STEP 3: choose spi speed(0=20MHz, 1=26.7MHz, 2=40MHz, 3=80MHz)"
echo "enter (0/1/2/3, default 2):"
read input
spi_speed=40
spi_speed=20
spi_speed=26.7
elif [ $input == 3 ]; then
spi_speed=80
spi_speed=40
fi
echo "spi speed: $spi_speed MHz"
echo ""
echo "STEP 4: choose spi mode(0=QIO, 1=QOUT, 2=DIO, 3=DOUT)"
echo "enter (0/1/2/3, default 0):"
read input
spi_mode=QIO
spi_mode=QOUT
spi_mode=DIO
spi_mode=DOUT
spi_mode=QIO
fi
echo "spi mode: $spi_mode"
echo ""
echo "STEP 5: choose spi size and map"
echo " 0= 512KB( 256KB+ 256KB)"
echo " 2=1024KB( 512KB+ 512KB)"
echo " 3=2048KB( 512KB+ 512KB)"
echo " 4=4096KB( 512KB+ 512KB)"
echo " 5=2048KB(1024KB+1024KB)"
echo " 6=4096KB(1024KB+1024KB)"
echo "enter (0/2/3/4/5/6, default 0):"
read input
spi_size_map=0
echo "spi size: 512KB"
echo "spi ota map: 256KB + 256KB"
spi_size_map=2
echo "spi size: 1024KB"
echo "spi ota map: 512KB + 512KB"
spi_size_map=3
echo "spi size: 2048KB"
elif [ $input == 4 ]; then
spi_size_map=4
echo "spi size: 4096KB"
elif [ $input == 5 ]; then
spi_size_map=5
echo "spi ota map: 1024KB + 1024KB"
elif [ $input == 6 ]; then
spi_size_map=6
spi_size_map=0
fi
echo ""
touch user/user_main.c
echo ""
echo "start..."
echo ""
make COMPILE=gcc BOOT=$boot APP=$app SPI_SPEED=$spi_speed SPI_MODE=$spi_mode SPI_SIZE_MAP=$spi_size_map
i use this:
#!/bin/bash
echo ""
echo "done"
echo ""
echo "start..."
echo ""
make COMPILE=gcc BOOT=new APP=0 SPI_SPEED=26.7 SPI_MODE=1 SPI_SIZE_MAP=6
if you want i can share all the docs and examples in C/c++ that i had
