Reboot after firmware update issue
Posted: Wed Mar 01, 2017 10:07 pm
Context : my own OTA update is in place and correctly working on all my old modules (ESPs 07 with 512kb flash); when the flashing is completed, the following sequence is executed (as per documentation), and everything works as expected.
My newest batch of modules came with 1Mb of flash, so I had to adjust everything; flashing still works as expected, but then I ran into a strange problem : when rebooting the module, it will not switch to the newly flashed content.
Tried with boot versions 1.5 and 1.6. SDK is 1.3.0. I know it old, but I cannot change this.
Currently, test module is using upper memory (aka user2); when rebooting, I can see the following on the output as the module restarts
Strange thing is that calling the upgrade reboot sequence even without flashing will not result in switching for this module, and I'm a bit puzzled as I have no clue what's wrong here.
Any help is appreciated.
Many thanks.
system_upgrade_flag_set(UPGRADE_FLAG_FINISH);
system_upgrade_reboot();
but then the bootloader then outputsreboot to use1
and goes back to upper memory firmware.2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user2 @ 81000
Many thanks.
