You can chat about native SDK questions and issues here.
By johnnyodonnell
#67520 Has anyone been able to connect to the AWS IoT platform while using mbedTLS with the Non-OS SDK? I am using the mbedTLS library from Espressif's site (https://espressif.com/en/products/hardware/esp8266ex/resources), but when I attempt to connect to AWS it fails after ServerHello and returns "Reason:[-0x7200]"
When I looked through the Wireshark logs, it showed that the esp8266 initiated the TCP connection close.
Below is the response from AWS. My esp8266 sends a FIN, ACK shortly after
Code: Select allFrame 33: 214 bytes on wire (1712 bits), 214 bytes captured (1712 bits) on interface 0
Ethernet II, Src: Netgear_4a:bb:7e (a0:63:91:4a:bb:7e), Dst: HonHaiPr_5b:f2:57 (90:48:9a:5b:f2:57)
Internet Protocol Version 4, Src: 35.166.227.117, Dst: 192.168.1.5
Transmission Control Protocol, Src Port: 8883, Dst Port: 50078, Seq: 2897, Ack: 85, Len: 148
[3 Reassembled TCP Segments (3044 bytes): #28(1448), #31(1448), #33(148)]
Secure Sockets Layer
    TLSv1.2 Record Layer: Handshake Protocol: Multiple Handshake Messages
        Content Type: Handshake (22)
        Version: TLS 1.2 (0x0303)
        Length: 3039
        Handshake Protocol: Server Hello
            Handshake Type: Server Hello (2)
            Length: 77
            Random
            Session ID Length: 32
            Session ID: 594dd75b48565f644050eb9f09aba8369de719ef4fe825a0...
            Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA256 (0x003d)
            Compression Method: null (0)
            Extensions Length: 5
            Extension: renegotiation_info
        Handshake Protocol: Certificate
            Handshake Type: Certificate (11)
            Length: 2912
            Certificates Length: 2909
            Certificates (2909 bytes)
                Certificate Length: 1563
                Certificate: 30820617308204ffa003020102021064c0578b6277f27035... (id-at-commonName=*.iot.us-west-2.amazonaws.com,id-at-organizationName=Amazon.com, Inc.,id-at-localityName=Seattle,id-at-stateOrProvinceName=Washington,id-at-countryName=US)
                Certificate Length: 1340
                Certificate: 3082053830820420a0030201020210513fb9743870b73440... (id-at-commonName=Symantec Class 3 Secure Server CA - G4,id-at-organizationalUnitName=Symantec Trust Network,id-at-organizationName=Symantec Corporation,id-at-countryName=US)
        Handshake Protocol: Certificate Request
            Handshake Type: Certificate Request (13)
            Length: 34
            Certificate types count: 3
            Certificate types (3 types)
            Signature Hash Algorithms Length: 26
            Signature Hash Algorithms (13 algorithms)
            Distinguished Names Length: 0
        Handshake Protocol: Server Hello Done
            Handshake Type: Server Hello Done (14)
            Length: 0
By davydnorris
#67576 Yeah I've seen exactly the same thing when trying to connect to other servers. The secure networking layer in the ESP SDK is infuriating - the SSL libs are broken when sending and don't support higher crypto standards, and the mbedTLS library messes up connections in client mode and won't connect more than once in server mode.
There are several groups trying to get around the broken libraries but it's very hard with pieces of the library closed by Espressif. :-(
By Dsbaha
#67799 You have to increase the ssl buffer size to at least 4096. it works great for me using mbedtls. Ive gotten greengrass working, too.
