I've installed the esp-open-sdk on my linux.
The previously version that I've used was the SDK V1.5 and with this version working my esp12 without any problem.
Now for a new project I've installed the V2.0.0_16_08_10 and compiled for a test the same blinky example (this has worked on sdk 1.5). But now my esp12 don't working(after compiling and flash). I saw that the adddress was changed from 0x4000 to 0x1000, is this a problem?
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "driver/uart.h"
// ESP-12 modules have LED on GPIO2. Change to another GPIO
// for other boards.
static const int pin = 2;
static volatile os_timer_t some_timer;
void some_timerfunc(void *arg)
//Do blinky stuff
if (GPIO_REG_READ(GPIO_OUT_ADDRESS) & (1 << pin))
// set gpio low
gpio_output_set(0, (1 << pin), 0, 0);
// set gpio high
gpio_output_set((1 << pin), 0, 0, 0);
os_printf("STA Mode - Client reconnected\r\n");
void ICACHE_FLASH_ATTR user_init()
// init gpio subsytem
gpio_init();
// configure UART TXD to be GPIO1, set as output
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_GPIO1);
gpio_output_set(0, 0, (1 << pin), 0);
uart_init(BIT_RATE_9600,BIT_RATE_9600);
// setup timer (500ms, repeating)
os_timer_setfn(&some_timer, (os_timer_func_t *)some_timerfunc, NULL);
os_timer_arm(&some_timer, 500, 1);
