You can chat about native SDK questions and issues here.
By durval
#89976 ...or directory" for some component, when you can see FILE.h is actually where it's supposed to be, you better double (or triple) check your `make menuconfig` and see whether there's an option to enable that component, *and* that option is turned ON (ie, true).
I just wasted a few hours due to that totally non-intuitive error message... only when I double checked the options in `make menuconfig` and saw an option to enable that specific component (in my case, ESP_CONSOLE) and that it was turned off, I managed to solve it.
For those that eventually will come a-googling, this is the exact message I received:
Code: Select allCC build/cmd_system/cmd_system.o
REDACTED/ESP8266_RTOS_SDK/examples/system/console/components/cmd_system/cmd_system.c:15:25: fatal error: esp_console.h: No such file or directory
compilation terminated.
make[1]: *** [REDACTED/ESP8266_RTOS_SDK/make/component_wrapper.mk:292: cmd_system.o] Error 1
make: *** [REDACTED/ESP8266_RTOS_SDK/make/project.mk:571: component-cmd_system-build] Error 2
I hope this can save someone frustration and wasted time.
Cheers,
-- Durval.
