By georgeloh
#70348
jummi wrote:I just got a new badge.
Disconnect the esp8266-01.
I give 5 volt voltage to the plate.
The D2 led D2 flashes constantly.
According to the schematic is the output to the relay.
I should not flash.
The supply voltage is correct.
Any ideas?
any solution for this yet?
By boray.gowda
#70708 Hi All,
I have the same issue with the relay board constantly flickering red.
Thanks to the folks that discovered the strings to turn on and turn off the relay.
Could someone tell me kindly how to read the state of the relay?
I'm trying to modify an existing piece of code to do a serial.write() with the required open/close string.
However, I'd like to also write routines to read the state.
It's been 25 years since I last wrote any code. Would really appreciate any help with this.
Thanks.
BG.
