By CTollemache
#61120 Hello!
I'm starting some physical computing with an Arduino Mega and an ESP-01. Would anyone be able to outline why I cannot send multiple commands to the ESP when I use the following code? I'm sure I'm missing something obvious, or I have a lack of understanding about the hardware.
(I've tried to piece this together from various tutorials around the web - as each tutorial often fails at a particular stage. Any help would be greatly appreciated.)
Arduino Sketch:
Code: Select all// params for the script
int TIMEOUT = 5000;
 * Send an AT command to the ESP and print the output to Serial
void sendCommand(String command, String keyword) {
  // print command for debug
  Serial.print("> sending ");
  Serial.println(command);
  // send the command to the ESP
  Serial1.println(command);
  // Print the response until `keyword` or a TIMEOUT
  long int time = millis();
  int current_char = 0;
  while((time + TIMEOUT) > millis()) {
    while(Serial1.available()) {
      char ch = Serial1.read();
      Serial.write(ch);
      if (ch == keyword[current_char]) {
        if (++current_char == keyword.length()) {
          Serial.println("> End of command response.");
          return;
  // Timeout
  Serial.print("> Timeout or error for '");
  Serial.print(command);
  Serial.println("'");
 * Setup
void setup () {
  Serial.println("> Arduino is go");
  Serial1.begin(115200);
  // check AT
  sendCommand("AT", "OK");
  // list the available connections
  sendCommand("AT+CWLAP", "OK");
 * Loop
void loop () {
Serial Monitor output:
Code: Select all> Arduino is go
> sending AT
AT
OK
> sending AT+CWLAP
> Timeout or error for 'AT+CWLAP'
By CTollemache
#61185 The issue is I don't understand serial communication, and I'm an lacking understanding of C (as well as being a total noob to hardware stuff like buffers, memory, etc). I've been reading through these resources:
https://hackingmajenkoblog.wordpress.com/2016/02/01/reading-serial-on-the-arduino/
http://forum.arduino.cc/index.php?topic=288234.0
I'll post a working program once I have it, and hopefully an explanation, as it could help someone out in the future.
