By Svedr
#61124 Hello to all!
I have a wifi shield ESP8266 ESP-12E mounted on the Arduino Uno.
( Model: ESP8266MOD, Vendor: AI-THINKER with 4 DIP switch on board )
I try with arduino uno, simpy mounted on it, and use this library
Code: Select allhttps://github.com/bportaluri/WiFiEsp
and example scannetworks:
Code: Select allThis example  prints the Wifi shield's MAC address, and
 scans for available Wifi networks using the Wifi shield.
 Every ten seconds, it scans again. It doesn't actually
 connect to any network, so no encryption scheme is specified.
 For more details see: http://yaab-arduino.blogspot.com/p/wifiesp.html
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
  // initialize serial for debugging
  // initialize serial for ESP module
  Serial1.begin(115200);
  // initialize ESP module
  WiFi.init(&Serial1);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // Print WiFi MAC address
  printMacAddress();
void loop()
  // scan for existing networks
  Serial.println("Scanning available networks...");
  listNetworks();
  delay(10000);
void printMacAddress()
  // get your MAC address
  byte mac[6];
  WiFi.macAddress(mac);
  // print MAC address
  char buf[20];
  sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
  Serial.print("MAC address: ");
  Serial.println(buf);
void listNetworks()
  // scan for nearby networks
  int numSsid = WiFi.scanNetworks();
  if (numSsid == -1) {
    Serial.println("Couldn't get a wifi connection");
    while (true);
  // print the list of networks seen
  Serial.print("Number of available networks:");
  Serial.println(numSsid);
  // print the network number and name for each network found
  for (int thisNet = 0; thisNet < numSsid; thisNet++) {
    Serial.print(thisNet);
    Serial.print(") ");
    Serial.print(WiFi.SSID(thisNet));
    Serial.print("\tSignal: ");
    Serial.print(WiFi.RSSI(thisNet));
    Serial.print(" dBm");
    Serial.print("\tEncryption: ");
    printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
  // read the encryption type and print out the name
  switch (thisType) {
    case ENC_TYPE_WEP:
      Serial.print("WEP");
      break;
    case ENC_TYPE_WPA_PSK:
      Serial.print("WPA_PSK");
      break;
    case ENC_TYPE_WPA2_PSK:
      Serial.print("WPA2_PSK");
      break;
    case ENC_TYPE_WPA_WPA2_PSK:
      Serial.print("WPA_WPA2_PSK");
      break;
    case ENC_TYPE_NONE:
      Serial.print("None");
      break;
In serial monitor " TIMEOUT"
I try with arduino mega, connect on pin 18,19 RX,TX and GND, +5V, the same: TIMEOUT
What am I doing wrong?
I expected that I would shield mount on Arduino, change library and i use it like ethernet shield.
For help, thank you....
