By TonyK59
#73505 Which diode exactly are you using ? Thanks !
Zod wrote:
RichardS wrote:Finding the perfect value that lies on some hairy fairy borderline of working and not working is not good.... resistors change value due to many circumstances, so your borderline solution tomorrow, or next week becomes your WTF moment.... because it "WAS" working.... remember... "WAS working" should be replaced with "it was on the edge of working"
A resistor really only works when you have only a switch to ground connected on reset pin, and not the amount of other circuitry as you do that interferes with it....
In conclusion:
Thanks for listening :-)
RichardS
PS. And how do I know.... just say.... "been there, done that"
The diode solution works perfectly. Thanks a lot.
By rudy
#73510 I prefer the 1N5817 because it has a lower forward voltage drop. Generally when a Schottky diode has a larger reverse voltage rating that comes at the expense of the forward voltage drop.
