By gotaquestion
#63848 I just got my esp8266 and I'm excited to hook it up. (fyi, the board has a v3 sticker on it)
I'll only use the esp8266 for wifi connection. Meaning, all my code will sit on the mega.
I found this wiring design
http://iliaslamprou.mysch.gr/virtuino/e ... n_plan.png
from this video
https://www.youtube.com/watch?v=wuNsnbkj9nk
1) What are all the resistors doing in this design?
2) This design hooks the 3.3v from the mega directly to the 8266. but I keep reading about making sure the power is regulated and to hook it up to a regulator chip.
3) I'll be receiving and parsing 1 url variable every second from a remote computer and then turning off individual leds representing a 30 second timer. Will the 8266 handle that or do I need to build in a buffer?
By icons
#63870 hmm...
according to data here https://www.arduino.cc/en/Main/arduinoBoardMega2560
the "3V3. A 3.3 volt supply generated by the on-board (Arduino mega) regulator. Maximum current draw is 50 mA..." which is nothing for the esp8266 to function properly. Better to have a separate voltage supply for 3.3v.
By gotaquestion
#63894
icons wrote:hmm...
this is so strange because most of all the circuit designs you see are where the arduino is powering the esp directly. how can I up the amps if I needed to power it from the board directly?
