By barth
#64822 I have same problem, if I use this code with Arduino Due
#define Serial_ESP Serial3
#define Serial_Debug Serial
// 12 - RST
// 18 CH-PD
// 11 GPIO0
void setup()
Serial_ESP.begin(115200);
Serial_Debug.begin(115200);
pinMode(18, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
digitalWrite(12, HIGH);
digitalWrite(18, HIGH);
//digitalWrite(11, HIGH);
delay(1); //max 15-17
digitalWrite(11, LOW);
//delayMicroseconds(600);
digitalWrite(12, LOW);
void loop()
if (Serial_ESP.available()) {
Serial_Debug.write(Serial_ESP.read());
Serial_Debug.flush();
if (Serial_Debug.available()) {
Serial_ESP.write(Serial_Debug.read());
Serial_ESP.flush();
Every think works fine - I can upload ESP with ESP Upload Tools - not directly from Arduino IDE! But it is not problem - You have to do compilatin and take hex file from TEMP directory
The problem is when I have use it for Arduino Mega 2560 - comunikation of course is - I can send data to ESP and take it to cpu - but upload hex file to ESP is imposible - I change boude speed and nothing :(
I somebody have any solution why on Due can do upload , on MEG not? Is hadware serial in Mega is other like DUE?
On FDTI also I Can load hex file, but it is not solution for me - I don't wona unconnect Esp module for programing each time...when I do any change in code ...
