By bkomac
#65559 Maybe for others...
On ESP 8266-12:
HC-12 .......ESP
TXD...........GPIO13
RXD...........GPIO15
On NodeMcu:
HC-12.......NodeMcu
TXD...........S1 (GPIO8)
RXD...........D4 (GPIO2)
Note: When flashing, I had to remove the wires from HC-12.
By Metalshark
#91423
MildaGenius wrote:Today successfully tested connection between Arduino Uno + HC12 and NodeMCU + HC12.
If you use the same code, you have wrong connection on NodeMCU side. For your connecting, you must change pins to 13, 15 in your code.
Check this:
http://www.esp8266.com/viewtopic.php?f=32&t=6602
When you say pins 13 &15 that's D7 and D8 right? If so, it didn't work for me. Any other suggestions?
