By LeKrist
#65391 Hi everyone,
I'm new to this forum. I've researched extensively before posting here.
I have a ESP8266 (see description here https://www.amazon.fr/gp/product/B01GCK ... UTF8&psc=1)
I have been able to upload sketches with the Arduino IDE without problems so far.
Now, I can't upload a sketch anymore.
Here are the upload logs from the arduino IDE:
Code: Select allSketch uses 254301 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 33996 bytes (41%) of dynamic memory, leaving 47924 bytes for local variables. Maximum is 81920 bytes.
/home/k/.arduino15/packages/esp8266/tools/esptool/0.4.9/esptool -vv -cd nodemcu -cb 9600 -cp /dev/ttyUSB0 -ca 0x00000 -cf /tmp/arduino_build_26397/sketch_mar04a.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to nodemcu
   setting baudrate from 115200 to 9600
   setting port from /dev/ttyUSB0 to /dev/ttyUSB0
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   espcomm_upload_mem
opening port /dev/ttyUSB0 at 9600
   tcgetattr
   tcsetattr
   serial open
opening bootloader
resetting board
trying to connect
An error occurred while uploading the sketch
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
As you can see in the description of the module it has a built-in usb adapter so I've always just used a USB cable from my computer to the module to upload.
When I try to upload I get the blue LED blinking everytime the 'trying to reconnect' message appears.
Also, if I open the Serial Monitor in Arduino IDE I can see that the last sketch I uploaded is correctly running.
Thanks for your help
By LeKrist
#65439 Thanks for your reply.
I have a devkit version so I don't need to connect any pin to upload sketches. I just connect the USB plug to my computer.
This worked for a long time. Do you think it could be the usb adapter on the module being faulty now?
Thanks
