By Svetlin
#65979 Hello!
I just purchased my first nodeMCU 1.0 development board with ESP-12E and CP2102 chip from eBay. My problem is when I plug it in with USB it really heats up, to that point it burns my finger and I can't hold it in my hand. Why is that and how can I solve this problem?
I can upload code via Arduino IDE without any problems.
I am worried that the heat will damage the board.
Thank you in advance,
Svetlin
By rudy
#65981 Measure the voltage and make sure it is correct. The +5 volts from the USB and the 3.3 volts on the module. Also check for shorted pins. It should not be getting hot like that.
