By Sky99
#67476 Hello there!
I'm new to the ESP scene but familiar with Arduino and AtMega µCs.
I wanted to phase out my arduino nanos for more modern stuffs, and the ESP8266 seems a good fit. So installed the boards definitions for the Arduino IDE in order to play with it, and could blink LEDs on various GPIOs, but i got into problems when i tried to use pushbuttons.
So i defined D2 as an INPUT_PULLUP, and thus tied it to the ground using a solid core wire in order to register a "push" on my button. However, once i did that, i could no longer flash anything to the chip.
The board i use is a NODEMCU board with µUSB and USB to serial converter. I've been able to flash things to the ESP without problems, until i did what i described earlier.
I had similar problems with 2 other boards, trying to do the same thing, but by then i did not understand why the board stopped working properly.
It still shows as a COM port in the Arduino IDE, but it fails to flash, returning the following error message :
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
error: espcomm_upload_mem failed
So now, i'm stuck with 3 ESP8266 that i can't flash, and i don't know what to do, nor what i did wrong.
Did i use a forbidden GPIO? can't i use INPUT_PULLUPs on the ESP? do i need an external pullup for my button?
Now, i'm really confused, and i'm not sure to understand what GPIOs i can safely use, nor how i bricked those units...
Any help would be apreciated :)
By schufti
#67495 if it was the pin marked D2 on the nodemcu board it is gpio4 which should be safe to be in whatever state during reset/power-up. Tying a pin - which could be configured as output - "hard" to V+ or gnd is never a good idea.
If you remove all "external" components from the nodemcu and connect it to USB, what happens?
Is ist recognized?
Does the LED on the sub-pcb (ESP-12) light up?
If the terminal window in Arduino-IDE is open and baud at 74880, do you see legible messages after pushing reset button?
P.S.: there was some post mentioning that internal pullups on gpio4/5 won't work; don't know if this is true.
By Sky99
#67565 Hello!
Basically, what i had was the same when removing all externall stuff.
I got around it, and de-bricked my ESPs by holding the flash button, plugging it in then flashing something.
After that it responds normally and can be flashed.
However, i still don't understand well why it wouldn't work.
The internal pullup on some pins beeing defective is an interesting lead, however, if so, i guess i would have fried the chip?
What bugs me is that the ESP would not flash, as if by tying a pin to ground i had put it in some weird mode...
So i'm not left wondering what pins are safe to use on a NodeMCU module?
