By KDB
#68438 Hi, on PIN GIO2 of ESP 8266 01 I connect a DHT temperature sensor. Booting the esp 8266 is very difficult. Sometimes the first attempt is successful but many times I must try many times ? Any ideas or hints ?
By QuickFix
#68457 Always make sure your schematics (ie. pull-up/pull-down resistors) are in order and your projects will perform as intended. :idea:
By KDB
#68498 Although i connected RST with 10 k ohm to vcc ( chpd to vcc )
sometimes boot is succesful.
Sometimes nothing happens
and sometimes :
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
who can explain the message ?
Who has a solution ? :twisted:
