By KDB
#68598 exception 0: Illegal instruction
Decoding 137 results
0x4021e1c0: ets_timer_handler_isr at ?? line ?
0x4021e1b8: ets_timer_handler_isr at ?? line ?
0x4021e1de: ets_timer_handler_isr at ?? line ?
0x4021de03: ets_snprintf at ?? line ?
0x4021d229: user_uart_wait_tx_fifo_empty at ?? line ?
0x401055ab: wdt_feed at ?? line ?
0x4010558c: wdt_feed at ?? line ?
0x40201ace: uart_write_char_d at ?? line ?
0x4021d243: user_uart_wait_tx_fifo_empty at ?? line ?
0x4021d217: user_uart_wait_tx_fifo_empty at ?? line ?
0x40235630: sleep_reset_analog_rtcreg_8266 at ?? line ?
0x4021da46: ets_vsnprintf at ?? line ?
0x4021d18c: user_uart_wait_tx_fifo_empty at ?? line ?
0x4021d19e: user_uart_wait_tx_fifo_empty at ?? line ?
0x40235350: sleep_reset_analog_rtcreg_8266 at ?? line ?
0x4021d160: user_uart_wait_tx_fifo_empty at ?? line ?
0x401055a5: wdt_feed at ?? line ?
0x401055a2: wdt_feed at ?? line ?
0x40201c1c: __wrap_system_restart_local at C:\Users\KDB\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_postmortem.c line 190
0x40231861: meas_tone_pwr_db at ?? line ?
0x402327ef: ram_get_fm_sar_dout at ?? line ?
0x4023184d: meas_tone_pwr_db at ?? line ?
0x402318fc: tx_pwr_backoff at ?? line ?
0x4022c3c5: set_txcap_reg at ?? line ?
0x4022e1e4: tx_pwctrl_init_cal at ?? line ?
0x4022e750: tx_pwctrl_init at ?? line ?
0x4022c33c: txpwr_offset at ?? line ?
0x4022ff60: chip_v6_initialize_bb at ?? line ?
0x4022ff75: chip_v6_initialize_bb at ?? line ?
0x4022bbe7: phy_init at ?? line ?
0x401068be: register_phy_ops at ?? line ?
0x40230d12: register_chipv6_phy at ?? line ?
0x402202f2: wifi_station_set_default_hostname at ?? line ?
0x4020204d: __wrap_register_chipv6_phy at C:\Users\KDB\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_phy.c line 261
0x40235280: sleep_reset_analog_rtcreg_8266 at ?? line ?
0x40106022: spi_flash_read at ?? line ?
0x4021ce7b: rijndaelKeySetupEnc at ?? line ?
0x4021d4f4: user_uart_wait_tx_fifo_empty at ?? line ?
0x4021d4cf: user_uart_wait_tx_fifo_empty at ?? line ?
0x40105868: wdt_feed at ?? line ?
0x40204f8d: ESP8266WebServer::_parseRequest(WiFiClient&) at C:\Users\KDB\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src/Parsing.cpp line 66
0x40205109: ESP8266WebServer::_parseRequest(WiFiClient&) at C:\Users\KDB\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src/Parsing.cpp line 123
0x4010020c: _umm_free at C:\Users\KDB\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1287
0x40230f20: set_rf_gain_stage10 at ?? line ?
0x4021acff: wpa_auth_uses_mfp at ?? line ?
0x4021ada5: wpa_auth_uses_mfp at ?? line ?
