By Jens001
#70186 Hi everybody,
I am in the very beginning with my first projects about ESP8266. Currently starting with a project - "presence recognition" via bluetooth. I would like to setup a Wemos D1 mini (V2.2) with HM-10 in order to find out if certain Siemens Bluetooth Tags are present or not.
The HM-10 is connected to the Wemos and the LED is blinking Red. So far I have it connected to Pin 5 and 6 which somehow works - but should not be correct. The serial monitor shows first BLE devices in the near.
My problem is, that I do not know on how to connect the HM-10 with the Wemos in the right way.
Following soruce code is used to connect both devices
#include <SPI.h>
#include <SoftwareSerial.h>
// Pins fuer Softserial definieren
SoftwareSerial bluetooth(5, 6); // TX, RX
As read in other internet sources, it must be connected as follows
Wemos TX <-> HM-10 RX
Wemos RX <-> HM-10 TX
But how can I call the Software Serial with TX and RX in the right way - what are the PIN numbers ?
Does somebody know on how to set this up correctly? And why is the HM-10 seemingly not getting a proper connection - since the red LED is blinking.
I would be happy about any further hint - thanks in advance.
Jens
