Help with NodeMCU ESP12-E ESP8266 WiFi Lua CP2102 V2 Module
PostPosted: Fri Dec 08, 2017 3:50 pm
by Skipjack6900
Hi all - hoping for help getting started with my new ESP8266. When I attach my new module to the Arduino IDE (ver 1.8.3):
- I selected the "NodeMCU 1.0 (ESP 12-E Module)" under the TOOLS menu,
- I added "http://arduino.esp8266.com/stable/package_esp8266com_index.json" to the preferences section under the FILE menu,
- I installed the CP210X driver for Windows10,
- I attached the USB cable from the ESP8266 module to the computer
When all that is done, the following indications are seen:
- No "port" is displayed in the Windows10 Device Manager (shows COM3 when the Arduino Uno is attached by USB)
- at the bottom of the IDE window, it shows "NodeMCU 1.0 (ESP12-E module), 80 MHz, 115200, 4M (3M SPFFs) on COM3"
- Using the WiFi analyzer on my smartphone shows a strong WiFi signal on channel 1 of the 2.4 GHz spectrum named "AI-THINKER_134034"
Since I am unable to select a "port" in the IDE TOOLS menu, I can't load a sketch, etc.
Please help if you can. Thanks very much.
Skipjack6900
Re: Help with NodeMCU ESP12-E ESP8266 WiFi Lua CP2102 V2 Mod
PostPosted: Mon Dec 18, 2017 11:03 pm
by Zachrey
I'm with you on this one! I am having trouble with:
Makerfocus 2pcs ESP8266 Module ESP-12E NodeMcu LUA WiFi Internet New Version Development Board
Have you tried ESPlorer? I can get something on it but I am still not sure if the ESP-12E is alive or not...
Hmmm... Just tried it on Arduino IDE and it is responding. In the "send" box at the top of the Serial Monitor, using a NodeMCU Lua command, I attempt to set wifi mode to "station" (similar to the AT command AT+CWMODE=1) but get error message "stdin:1: ...
wifi.setmode(wifi.STATION)
stdin:1: unexpected symbol near 'ÿ'
Which in not very helpful.. Maybe I need to flash a new firmware on it??
PostPosted: Wed Dec 20, 2017 4:45 pm
by Skipjack6900
Zachrey wrote:I'm with you on this one! I am having trouble with:
Thanks for the info. I've not tried ESPlorer yet and will download it and try it out.
