By glennpierce
#73215 Hi
How accurate is the esp8266 ADC pin ?
I am using the esp8266 on a wemos d1 mini board and have injected a voltage on the adc pin so the voltage
on the esp8266 A0 pin is 1.0 volt or as close I can measure it with my two meters. I have faith it should be close to 1 volt.
However, this seems to give readings of 957-962 on the pin read.
Does anyone know why this is not closer to 1024 ?
Thanks
