By kidbreaker22
#73360 Basically what the title says!
I coded a light sensor test where it works on my Genuino Uno board and then tried on my ESP8266 V3 NodeMCU (http://www.smartarduino.com/nodemcu-bas ... 94571.html) and it gives me random stuff in the Serial Monitor. Am I doing something wrong or am I missing an information that I don't know about in ESP8266 that I can't do while it's allowed in Genuino Uno? Can someone please help me figure out with this stuff?
Thank you.
Code: Select allint sensorValue = 0;
int value = 0;
const int sensorPin = A0;
const int LEDPin = 8;
  Serial.begin(9600);
  pinMode(LEDPin, OUTPUT);
  sensorValue = analogRead(sensorPin);
  Serial.print("Sensor Value: ");
  Serial.println(sensorValue);
  value = 255 - sensorValue/4;
  Serial.print("Analog Value of Pin D8: ");
  Serial.println(value);
  analogWrite(LEDPin, value);
By jankop
#73422 Pin 8 is dedicated for flash memory! Your system colapsed. Change the pin to other free. I tried the program, it works.
here is your error message at 115200 baud:
Code: Select allwdt reset
tail 8
chksum 0x2d
csum 0x2d
v4ceabea9
~ld
