By jme
#78028 Hi,
I'm using a ESP to control neopixels.
A domoticz server is sending HTTP request to the esp to change neopixel effects.
Sometims the esp crash with this log:
Code: Select allSoft WDT reset
ctx: cont
sp: 3fffefe0 end: 3fffeff0 offset: 01b0
>>>stack>>>
<<<stack<<<
 ets Jan  8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
Any idea what can cause this ?
If the code is needed, i can post it .
By jme
#78063 Hi,
Here is the code bellow.
I think the server is sending the http request but i see in the logs that somethimes it didn't get a answer.
So maybe ESP is busy with something else or is not reachable.
I don't know if the server didn't get a answer if it send the request again and again,flooding the esp, that may be the cause of the crash.
i saw on youtube someone using MQTT, is it more reliable than HTTP to send request to esp ?
the idea is to play a neopixel effect until the domticz server send a new request for a new effect, i have some loops, these can be the issue also, what do you think ?
Code: Select all#define FASTLED_ESP8266_RAW_PIN_ORDER
#include <bitswap.h>
#include <chipsets.h>
#include <color.h>
#include <colorpalettes.h>
#include <colorutils.h>
#include <controller.h>
#include <cpp_compat.h>
#include <dmx.h>
#include "FastLED.h"
#include <fastled_config.h>
#include <fastled_delay.h>
#include <fastled_progmem.h>
#include <fastpin.h>
#include <fastspi.h>
#include <fastspi_bitbang.h>
#include <fastspi_dma.h>
#include <fastspi_nop.h>
#include <fastspi_ref.h>
#include <fastspi_types.h>
#include <hsv2rgb.h>
#include <led_sysdefs.h>
#include <lib8tion.h>
#include <noise.h>
#include <pixelset.h>
#include <pixeltypes.h>
#include <platforms.h>
#include <power_mgt.h>
#include <Adafruit_NeoPixel.h>
#include <WiFiClient.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266mDNS.h>
#include <ESP8266WebServer.h>   // Include the WebServer library
#include <ArduinoOTA.h>
//#include <WebSocketsServer.h>
#include <EEPROM.h>
#define NUM_LEDS 60
CRGB leds[NUM_LEDS];
#define PIN 14
int i;
int b;
int z=8;
byte pixel=0;
int message;
ESP8266WiFiMulti wifiMulti;     // Create an instance of the ESP8266WiFiMulti class, called 'wifiMulti'
ESP8266WebServer server(80);    // Create a webserver object that listens for HTTP request on port 80
//WebSocketsServer webSocket(81);    // create a websocket server on port 81
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
const int led = 2;
WiFiClient client;
int status = 0;
void handleRoot();              // function prototypes for HTTP handlers
void handleNotFound();
void handleLED();
void handleLEDoff();
void httprequest();
void welcome();
void bye();
void handleGenericArgs();
void startWiFi();
void startOTA();
void startMDNS();
void setup(void){
  Serial.begin(115200);         // Start the Serial communication to send messages to the computer
  delay(10);
  Serial.println('\n');
  FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  pinMode(led, OUTPUT);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
   FastLED.addLeds<NEOPIXEL, PIN>(leds, NUM_LEDS);
  startWiFi();
  startOTA();
  //startWebSocket();            // Start a WebSocket server
  startMDNS();                 // Start the mDNS responder
  httprequest();
 // startServer();  // Start a HTTP server with a file read handler and an upload handler
//webSocket.loop();                           // constantly check for websocket events
  server.handleClient();                      // run the server
  ArduinoOTA.handle();     // listen for OTA events
//Serial.println("message =");
//Serial.println(message);
//connection au WIFI
void startWiFi() { // Start a Wi-Fi access point, and try to connect to some given access points. Then wait for either an AP or STA connection
 // WiFi.softAP(ssid, password);             // Start the access point
 // Serial.print("Access Point \"");
 // Serial.print(ssid);
 // Serial.println("\" started\r\n");
  wifiMulti.addAP("MERAKI", "azerty");   // add Wi-Fi networks you want to connect to
// wifiMulti.addAP("WIFI", "trasschaert12");
  wifiMulti.addAP("Wireless", "toxikwifi");
IPAddress ip(192,168,1,18);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
WiFi.config(ip, gateway, subnet);
Serial.println("Connecting");
  while (wifiMulti.run() != WL_CONNECTED && WiFi.softAPgetStationNum() < 1) {  // Wait for the Wi-Fi to connect
    delay(250);
    Serial.print('.');
  Serial.println("\r\n");
  if(WiFi.softAPgetStationNum() == 0) {      // If the ESP is connected to an AP
    Serial.println(WiFi.SSID());             // Tell us what network we're connected to
    Serial.print("IP address:\t");
    Serial.print(WiFi.localIP());            // Send the IP address of the ESP8266 to the computer
  } else {                                   // If a station is connected to the ESP SoftAP
    Serial.print("Station connected to ESP8266 AP");
//Fin connection au WIFI
//Debut OTA
void startOTA() { // Start the OTA service
  ArduinoOTA.setHostname("ESP8266");
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
    Serial.println("\r\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("OTA ready\r\n");
//Fin OTA
//debut MDNS
void startMDNS() { // Start the mDNS responder
  MDNS.begin("esp8266");                        // start the multicast domain name server
  Serial.print("mDNS responder started: http://");
  Serial.print("esp8266");
  Serial.println(".local");
//Fin MDNS
//Web socket
//void startWebSocket() { // Start a WebSocket server
 // webSocket.begin();                          // start the websocket server
 // webSocket.onEvent(webSocketEvent);          // if there's an incomming websocket message, go to function 'webSocketEvent'
 // Serial.println("WebSocket server started.");
//fin websoket
void resetClient() {
client.stop();
server.begin();
void httprequest(){
server.on("/", [](){
  int message=server.arg("msg").toInt();
   Serial.println("-----------");
 switch (message) {
      case 0  : {
        server.send(200, "text/plain", "RGBLoop");
        while (message == 0){
      resetClient();
                // RGBLoop - no parameters
                RGBLoop();
                break;
    case 1  : {
      server.send(200, "text/plain", "FadeInOut");
      while (message == 1){
      resetClient();
                // FadeInOut - Color (red, green. blue)
                FadeInOut(0xff, 0x00, 0x00); // red
                FadeInOut(0xff, 0xff, 0xff); // white
                FadeInOut(0x00, 0x00, 0xff); // blue
                break;
    case 2  : {
      server.send(200, "text/plain", "Strobe");
      while (message == 2){
      resetClient();
                // Strobe - Color (red, green, blue), number of flashes, flash speed, end pause
                Strobe(0xff, 0xff, 0xff, 10, 50, 1000);
                break;
    case 3  : {
      server.send(200, "text/plain", "HalloweenEyes");
      while (message == 3){
      resetClient();
                // HalloweenEyes - Color (red, green, blue), Size of eye, space between eyes, fade (true/false), steps, fade delay, end pause
                HalloweenEyes(0xff, 0x00, 0x00,
                              1, 4,
                              true, random(5,50), random(50,150),
                              random(1000, 10000));
                              1, 4,
                break;
    case 4  : {
      server.send(200, "text/plain", "CycloBounce");
      while (message == 4){
      resetClient();
                // CylonBounce - Color (red, green, blue), eye size, speed delay, end pause
                CylonBounce(0xff, 0x00, 0x00, 4, 10, 50);
                break;
    case 5  : {
      server.send(200, "text/plain", "NewKitt");
      while (message == 5){
      resetClient();
                // NewKITT - Color (red, green, blue), eye size, speed delay, end pause
                NewKITT(0xff, 0x00, 0x00, 8, 10, 50);
                break;
    case 6  : {
      server.send(200, "text/plain", "Twinkle");
      while (message == 6){
      resetClient();
                // Twinkle - Color (red, green, blue), count, speed delay, only one twinkle (true/false)
                Twinkle(0xff, 0x00, 0x00, 10, 100, false);
                break;
    case 7  : {
      server.send(200, "text/plain", "TwinkleRandom");
      while (message == 7){
      resetClient();
                // TwinkleRandom - twinkle count, speed delay, only one (true/false)
                TwinkleRandom(20, 100, false);
                break;
    case 8  : {
      server.send(200, "text/plain", "Sparkle");
      while (message == 8){
      resetClient();
                // Sparkle - Color (red, green, blue), speed delay
                Sparkle(0xff, 0xff, 0xff, 0);
                break;
    case 9  : {
      server.send(200, "text/plain", "Snowsparkle");
      while (message == 9){
      resetClient();
                // SnowSparkle - Color (red, green, blue), sparkle delay, speed delay
                SnowSparkle(0x10, 0x10, 0x10, 20, random(100,1000));
                break;
    case 10 : {
      server.send(200, "text/plain", "Running Lights");
      while (message == 10){
      resetClient();
                // Running Lights - Color (red, green, blue), wave dealy
                RunningLights(0xff,0x00,0x00, 50);  // red
                RunningLights(0xff,0xff,0xff, 50);  // white
                RunningLights(0x00,0x00,0xff, 50);  // blue
                break;
    case 11 : {
      server.send(200, "text/plain", "Color Wipe");
      while (message == 11){
      resetClient();
                // colorWipe - Color (red, green, blue), speed delay
                colorWipe(0x00,0xff,0x00, 50);
                colorWipe(0x00,0x00,0x00, 50);
                break;
    case 12 : {
      server.send(200, "text/plain", "RainbowCycle");
      while (message == 12){
      resetClient();
                // rainbowCycle - speed delay
                rainbowCycle(20);
                break;
    case 13 : {
      server.send(200, "text/plain", "TheatreChase");
      while (message == 13){
      resetClient();
                // theatherChase - Color (red, green, blue), speed delay
                theaterChase(0xff,0,0,50);
                break;
    case 14 : {
      server.send(200, "text/plain", "theaterChaseRainbow");
      while (message == 14){
      resetClient();
                // theaterChaseRainbow - Speed delay
                theaterChaseRainbow(50);
                break;
    case 15 : {
      server.send(200, "text/plain", "Fire");
      while (message == 15){
      resetClient();
                // Fire - Cooling rate, Sparking rate, speed delay
                Fire(55,120,15);
                break;
              // simple bouncingBalls not included, since BouncingColoredBalls can perform this as well as shown below
              // BouncingColoredBalls - Number of balls, color (red, green, blue) array, continuous
              // CAUTION: If set to continuous then this effect will never stop!!!
    case 16 : {
      server.send(200, "text/plain", "Mimic BouncingBall");
      while (message == 16){
      resetClient();
                // mimic BouncingBalls
                byte onecolor[1][3] = { {0xff, 0x00, 0x00} };
                BouncingColoredBalls(1, onecolor, false);
                break;
    case 17 : {
      server.send(200, "text/plain", "Multiple Color Balls");
      while (message == 17){
      resetClient();
                // multiple colored balls
                byte colors[3][3] = { {0xff, 0x00, 0x00},
                                      {0xff, 0xff, 0xff},
                                      {0x00, 0x00, 0xff} };
                BouncingColoredBalls(3, colors, false);
                break;
    case 18 : {
      server.send(200, "text/plain", "Meteor Rain");
      while (message == 18){
      resetClient();
                // meteorRain - Color (red, green, blue), meteor size, trail decay, random trail decay (true/false), speed delay
                meteorRain(0xff,0xff,0xff,10, 64, true, 30);
                break;
    case 19  : {
      server.send(200, "text/plain", "Black Sparkle");
      while (message == 19){
      resetClient();
                BlackSparkle(0, 0, 0, 20, random(100,1000));
                break;
    case 98 : {
      server.send(200, "text/plain", "Welcome Home");
     while (message == 98){
      resetClient();
      welcome();
      break;
    case 97 : {
      server.send(200, "text/plain", "Bye Bye");
      while (message == 97){
      resetClient();
      bye();
      break;
    case 99 : {
      server.send(200, "text/plain", "All off");
      while (message == 99){
      resetClient();
      alloff();
      break;
  server.on("/LED", handleLED);  // Call the 'handleLED' function when a POST request is made to URI "/LED"// Call the 'handleRoot' function when a client requests URI "/"
  server.on("/welcome", welcome);
  server.on("/bye", bye);
  server.on("/wait",wait);
  server.onNotFound(handleNotFound);        // When a client requests an unknown URI (i.e. something other than "/"), call function "handleNotFound"
  server.begin();                           // Actually start the server
void handleRoot() {                         // When URI / is requested, send a web page with a button to toggle the LED
  server.send(200, "text/html", "<form action=\"/LED\" method=\"POST\"><input type=\"submit\" value=\"Toggle LED\"></form>");
  server.send(200, "text/html", "<form action=\"/welcome\" method=\"POST\"><input type=\"submit\" value=\"welcome\"></form>");
void alloff(){
 setAll(0,0,0);
      showStrip();
        delay(30);
void wait(){
void handleLED() {                          // If a POST request is made to URI /LED
 // digitalWrite(led,!digitalRead(led)); // Change the state of the LED
  //server.sendHeader("Location","/");        // Add a header to respond with a new location for the browser to go to the home page again
 // server.send(303);
  // Serial.println('\n');
  //Serial.print("LED ON ");// Send it back to the browser with an HTTP status 303 (See Other) to redirect
  Serial.print("welcome home ");// Send it back to the browser with an HTTP status 303 (See Other) to redirect
for (i=0;i<60;i++) {
leds[i] = CRGB::GhostWhite;
        FastLED.show();
        delay(30);
        for (b=0;b<60;b++){
        leds[b] = CRGB::Black;
        FastLED.show();
        delay(30);
  server.send(303);
void handleNotFound(){
  server.send(404, "text/plain", "404: Not found"); // Send HTTP status 404 (Not Found) when there's no handler for the URI in the request
//LED Effects
void welcome() {
        FastLED.show();
        delay(30);
delay(1000);
        for (b=0;b<60;b++){
        FastLED.show();
        delay(30);
void bye()
for (i=60;i>0;i--) {
        FastLED.show();
        delay(30);
        for (b=60;b>0;b--){
        FastLED.show();
        delay(30);
// ** LEDEffect Functions **
void RGBLoop(){
  for(int j = 0; j < 3; j++ ) {
    // Fade IN
    for(int k = 0; k < 256; k++) {
      switch(j) {
        case 0: setAll(k,0,0); break;
        case 1: setAll(0,k,0); break;
        case 2: setAll(0,0,k); break;
      showStrip();
      delay(3);
    // Fade OUT
    for(int k = 255; k >= 0; k--) {
      switch(j) {
      showStrip();
      delay(3);
void FadeInOut(byte red, byte green, byte blue){
  float r, g, b;
  for(int k = 0; k < 256; k=k+1) {
    r = (k/256.0)*red;
    g = (k/256.0)*green;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
  for(int k = 255; k >= 0; k=k-2) {
    r = (k/256.0)*red;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause){
  for(int j = 0; j < StrobeCount; j++) {
    setAll(red,green,blue);
    showStrip();
    delay(FlashDelay);
    setAll(0,0,0);
    showStrip();
    delay(FlashDelay);
 delay(EndPause);
void HalloweenEyes(byte red, byte green, byte blue,
                   int EyeWidth, int EyeSpace,
                   boolean Fade, int Steps, int FadeDelay,
                   int EndPause){
  randomSeed(analogRead(0));
  int i;
  int StartPoint  = random( 0, NUM_LEDS - (2*EyeWidth) - EyeSpace );
  int Start2ndEye = StartPoint + EyeWidth + EyeSpace;
  for(i = 0; i < EyeWidth; i++) {
    setPixel(StartPoint + i, red, green, blue);
    setPixel(Start2ndEye + i, red, green, blue);
  showStrip();
  if(Fade==true) {
    float r, g, b;
    for(int j = Steps; j >= 0; j--) {
      r = j*(red/Steps);
      g = j*(green/Steps);
      b = j*(blue/Steps);
        setPixel(StartPoint + i, r, g, b);
        setPixel(Start2ndEye + i, r, g, b);
      showStrip();
      delay(FadeDelay);
  setAll(0,0,0); // Set all black
  delay(EndPause);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// used by NewKITT
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i =((NUM_LEDS-EyeSize)/2); i>=0; i--) {
    setAll(0,0,0);
    setPixel(NUM_LEDS-i, red/10, green/10, blue/10);
      setPixel(NUM_LEDS-i-j, red, green, blue);
    setPixel(NUM_LEDS-i-EyeSize-1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = 0; i<=((NUM_LEDS-EyeSize)/2); i++) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// used by NewKITT
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void Twinkle(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
  for (int i=0; i<Count; i++) {
     setPixel(random(NUM_LEDS),red,green,blue);
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
     setPixel(random(NUM_LEDS),random(0,255),random(0,255),random(0,255));
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void Sparkle(byte red, byte green, byte blue, int SpeedDelay) {
  int Pixel = random(NUM_LEDS);
  setPixel(Pixel,red,green,blue);
  showStrip();
  delay(SpeedDelay);
  setPixel(Pixel,0,0,0);
void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
  setPixel(Pixel,0xff,0xff,0xff);
  showStrip();
  delay(SparkleDelay);
  showStrip();
  delay(SpeedDelay);
void BlackSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
  setAll(0,0,0);
  showStrip();
  showStrip();
  delay(SpeedDelay);
void RunningLights(byte red, byte green, byte blue, int WaveDelay) {
  int Position=0;
  for(int i=0; i<NUM_LEDS*2; i++)
      Position++; // = 0; //Position + Rate;
      for(int i=0; i<NUM_LEDS; i++) {
        // sine wave, 3 offset waves make a rainbow!
        //float level = sin(i+Position) * 127 + 128;
        //setPixel(i,level,0,0);
        setPixel(i,((sin(i+Position) * 127 + 128)/255)*red,
                   ((sin(i+Position) * 127 + 128)/255)*green,
                   ((sin(i+Position) * 127 + 128)/255)*blue);
      showStrip();
      delay(WaveDelay);
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
  for(uint16_t i=0; i<NUM_LEDS; i++) {
      setPixel(i, red, green, blue);
      showStrip();
      delay(SpeedDelay);
void rainbowCycle(int SpeedDelay) {
  byte *c;
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< NUM_LEDS; i++) {
      c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
      setPixel(i, *c, *(c+1), *(c+2));
    showStrip();
    delay(SpeedDelay);
// used by rainbowCycle and theaterChaseRainbow
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
  } else {
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
void theaterChase(byte red, byte green, byte blue, int SpeedDelay) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < NUM_LEDS; i=i+3) {
        setPixel(i+q, red, green, blue);    //turn every third pixel on
      showStrip();
      delay(SpeedDelay);
        setPixel(i+q, 0,0,0);        //turn every third pixel off
void theaterChaseRainbow(int SpeedDelay) {
  byte *c;
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
          c = Wheel( (i+j) % 255);
          setPixel(i+q, *c, *(c+1), *(c+2));    //turn every third pixel on
        showStrip();
        delay(SpeedDelay);
void Fire(int Cooling, int Sparking, int SpeedDelay) {
  static byte heat[NUM_LEDS];
  int cooldown;
  // Step 1.  Cool down every cell a little
  for( int i = 0; i < NUM_LEDS; i++) {
    cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
    if(cooldown>heat[i]) {
      heat[i]=0;
    } else {
      heat[i]=heat[i]-cooldown;
  // Step 2.  Heat from each cell drifts 'up' and diffuses a little
  for( int k= NUM_LEDS - 1; k >= 2; k--) {
    heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
  // Step 3.  Randomly ignite new 'sparks' near the bottom
  if( random(255) < Sparking ) {
    int y = random(7);
    heat[y] = heat[y] + random(160,255);
    //heat[y] = random(160,255);
  // Step 4.  Convert heat to LED colors
  for( int j = 0; j < NUM_LEDS; j++) {
    setPixelHeatColor(j, heat[j] );
  showStrip();
  delay(SpeedDelay);
void setPixelHeatColor (int Pixel, byte temperature) {
  // Scale 'heat' down from 0-255 to 0-191
  byte t192 = round((temperature/255.0)*191);
  // calculate ramp up from
  byte heatramp = t192 & 0x3F; // 0..63
  heatramp <<= 2; // scale up to 0..252
  // figure out which third of the spectrum we're in:
  if( t192 > 0x80) {                     // hottest
    setPixel(Pixel, 255, 255, heatramp);
  } else if( t192 > 0x40 ) {             // middle
    setPixel(Pixel, 255, heatramp, 0);
  } else {                               // coolest
    setPixel(Pixel, heatramp, 0, 0);
void BouncingColoredBalls(int BallCount, byte colors[][3], boolean continuous) {
  float Gravity = -9.81;
  int StartHeight = 1;
  float Height[BallCount];
  float ImpactVelocityStart = sqrt( -2 * Gravity * StartHeight );
  float ImpactVelocity[BallCount];
  float TimeSinceLastBounce[BallCount];
  int   Position[BallCount];
  long  ClockTimeSinceLastBounce[BallCount];
  float Dampening[BallCount];
  boolean ballBouncing[BallCount];
  boolean ballsStillBouncing = true;
  for (int i = 0 ; i < BallCount ; i++) {
    ClockTimeSinceLastBounce[i] = millis();
    Height[i] = StartHeight;
    Position[i] = 0;
    ImpactVelocity[i] = ImpactVelocityStart;
    TimeSinceLastBounce[i] = 0;
    Dampening[i] = 0.90 - float(i)/pow(BallCount,2);
    ballBouncing[i]=true;
  while (ballsStillBouncing) {
      TimeSinceLastBounce[i] =  millis() - ClockTimeSinceLastBounce[i];
      Height[i] = 0.5 * Gravity * pow( TimeSinceLastBounce[i]/1000 , 2.0 ) + ImpactVelocity[i] * TimeSinceLastBounce[i]/1000;
      if ( Height[i] < 0 ) {
        Height[i] = 0;
        ImpactVelocity[i] = Dampening[i] * ImpactVelocity[i];
        if ( ImpactVelocity[i] < 0.01 ) {
          if (continuous) {
          } else {
            ballBouncing[i]=false;
      Position[i] = round( Height[i] * (NUM_LEDS - 1) / StartHeight);
    ballsStillBouncing = false; // assume no balls bouncing
      setPixel(Position[i],colors[i][0],colors[i][1],colors[i][2]);
      if ( ballBouncing[i] ) {
    showStrip();
    setAll(0,0,0);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
// used by meteorrain
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
// ** FastLed/NeoPixel Common Functions **
// Apply LED color changes
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
// Set a LED color (not yet visible)
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
// Set all LEDs to a given color and apply it (visible)
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
  showStrip();
By schufti
#78067 just at a quick glimpse:
Code: Select all      while (message == 1){
      resetClient();
how does this loop end?
and no, mqtt is not a substitute for http
